Question about Vacuums
Bosch ergomaxx 1800
Need to open up to clean out motor compartment 6 screws out no access bosch ergomaxx 1800
3 Suggested Answers
  • 3 Answers
SOURCE: i have a bosch ergomaxx 2000w which I need to
Got the same !
Remove both back wheels (just pull gently with a screwdriver), then with a big screwdriver pull the cover while pulling plastic locks in the side holes (under the wheels) whith a small screwdriver.
Posted on Oct 16, 2010
  • 6 Answers
SOURCE: cant access motor compartment
Those screws are hidden under the plastic that you press to make the cord retract.The way I get into that area is to pry it up from the side of the cord retract panel.They take a fair amount of leverage to get it off but it is straightforward from there-Good Luck,
Posted on Oct 26, 2008
Hi my bosch ergomaxx 1800w vacuum cleaner isn't
Some of those machines have a breaker button on the back of the body that needs to be reset. It will be located on the back bottom part of the body housing.
Sep 05, 2014 | Vacuums
The lights which tell you if you are going at the right speed on my Bissell PROHeat Pro-Tech have stopped working. Just wondering if this could be as simple as a bulb or more serious. Also, how do you...
I have this same model and never noticed the lights telling me the "correct speed" learn something new everyday....
the clear plastic hood removes with a few screws connected to the base at the bottom. the top part snaps out. :)
Mar 26, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a bosch ergomaxx 2000w which I need to strip down and clean. Ive found 6 torx screws bit still can't remove the coloured plastic cover. How do I remove it?
Got the same !
Jan 16, 2010 | Bosch Vacuums
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Can't refit dustbag to bosch ergomaxx barrel cleaner
The bag slips into the holder which should be attached to the machine. If you have taken this out by mistake and thrown it you'll have to contact Bosch to order a new bag holder.
Jan 22, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Cant access motor compartment
Oct 20, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Need to open motor compartment
Use a flat blade screwdriver, The dusy compartemnt door will come off by pushing it back, it just pops out. Then the rear top cover is held on by a tab, one in each corner. Put the flat blat in the slot at the bottom of the cover and work it until it pops loose. Then there are 2 screws to tak out to remove the cover over the motor and cord reel asm. But now you can get to the motor.
Jan 24, 2008 | Panasonic MC-V9620 Canister Vacuum
Problem with motor; need to open the motor compartment
The top piece near the back comes off, use a screw driver to pry the corners out then it will come off. Then you can get to the 2 screws holding the motor housing off. When you put it back on, it just snaps in place.
Oct 24, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
182 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
