Question about Microsoft Office Outlook 2003 for PC
Auto protect when i have logged off and switch back on the Auto-Protection is switched off, we keep switching it back on but it keeps comeing up saying an error. we have done a full scan we have also done a liveupdate like its asks then it says restart the computer and when it comes back on its still switched off.
    Genius:
  • 1,226 Answers
May be your infected by virus that your autoprotect cannot delete it. try uninstall and reinstall the autoprotect program in your system do not forget to update.if see same problems try any potent antivirus like kaspersky, AVG and many others.
cheer,
mel
Posted on Dec 13, 2007
When I go to use apps, the screen saver kicks in after a few minutes. When I go to the Burn Screen Protection, it is grayed out and says "this function isn't available."
Try switching the "Source" to TV (click on "Source" button on the remote), then going to Menu>System>Screen Burn Protection. It shouldn't be grayed out anymore and you can adjust it. Then switch the Source back to whatever it was before.
Jan 02, 2016 | Samsung Televison & Video
Philips 720 transcription tape runs too fast
The deck is bad needs a new worm gear for the functioning motor.
Jan 22, 2014 | Philips PSP-LFH0720/52 Model 720 Analog...
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
Samsung tv ct-21z45ml problem is power supply ,work in 110 volts but dont on 220 volt
Possible there is a fault in the auto detection circuit or a protection in force when it is powered in the 220 volt line. It is important to isolate and check the SMPS - the switch mode power supply as it can be faulty in the auto detection- auto protection feedback section, Check the opto-coupler section.
please check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Aug 24, 2011 | Televison & Video
My memory card keeps saying it is in write protection and I keep flipping the switch on the side but it doesn't work, how do I fix it?
The write protection is initiated by your camera, not the lock switch on the side of the card. Check your manual for the procedure to cancel write protection.
Jun 30, 2011 | Nikon Coolpix S3000 Digital Camera
Asus 19inch LCD monitor keeps auto adjusting and turn off after 2secs. . i do reset it . . nothing happens. .it keeps auto adjusting itself repeatedly . . pls help me
The Auto knob maybe mechanically stuck or the internal switch may be defective. Try pressing the Auto switch firmly 10-15 times,If monitor works now the switch is defective and needs replacement. Do rate the solution.
Samir
Feb 07, 2011 | ASUS 19 Inch Sxga 1280X1024, 5MS,...
Using a SanDisk Micro in a SanDisk adapter in a USB Card Reader. My system keeps reporting the card is write protected, no matter the position of the lock switch. I formatted the SD in my phone, no...
Most SD memory cards have a tiny slide switch on the edge of the card. Move this slide switch from Read to Write to turn off the write protection.
Nov 12, 2010 | SanDisk 2GB microSD Memory Card
I have a 2001 Buick Century and the Driver side power window switch is moving correctly. It is very hard to push down on and when it goes down it wont go back up unless I move the switch around. It...
Hello: You will have to replace the switch. You have to remove the switch plate, to remove plate you use a 1/4 in straight slot screwdriver, put protection under the screwdriver (to protect panel) push down on the screwdriver go under the plate on the end, there is a spring clip you have to push on and pry up on at the same time. Un plug connectors on switch plate(they only go on one way) then remove screws thad holds the window switch assembly. Be sure to get the switch with the auto feature.
Nov 02, 2010 | 2001 Buick Century
My samsung mini DV camera SC-D372 keeps flashing "Protection" on the playback screen
turn the camcorder off, take out the tape, look for the protection tab on the side of the tape and switch it to the other side.
protection is a feature of your tape to keep you from taping over important videos saved in your tape
Mar 02, 2009 | Samsung SC-D372 Camcorder
Write-Protection
Check the Manual- there is a comprehensive manual as a PDF file on the CD that came with the camera. depending on the card type some have a small switch- is this one of them?
Aug 02, 2007 | Nikon COOLPIX L4 Digital Camera
Microsoft Office Outlook 2003 for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
