Question about E-Machines etower 600is PC Desktop
Device manager error !
The PCI Simple Communications controller is not being recognized by Device Manager. Using Windows 2000 and my pc is an old clunker. I have a etower 600is. Can you help resolve this???
    President:
  • 2,351 Answers
It sound like you need a device driver which win2000 may not included. Try this link:
http://www.driverfiles.net/Other/Emachines/eTower-600is/download/page,sh,41224,568,3,.html
Posted on Dec 05, 2007
Pci simple communications controller
please go to this link and download your drivers for your motherboard....you may have to download or install drivers for your hardware addons that you installed as well..
Support For H55M E23 MSI Canada Motherboard The world leader in...
Apr 26, 2014 | MSI H55ME23 Motherboard micro ATX LGA1156...
PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Jun 29, 2010 | Intel D845GVSR Motherboard
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
Nov 29, 2009 | SimpleTech SimpleStation (STI-PNPR/PCI) PC...
I recently formatted a second harddrive on my dimension L933r to download windows 7 all works fine but i can not change screen resolution and now i can not find the drive for the pci simple communications...
Hello.
Not certain if you still need this, but ...
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware
Hope this helps.
Nov 17, 2009 | E-Machines eMachines W2686 PC Desktop
I need drivers for PCI Simple Communication Controller for a older computer running xp
download 50000 pc drivers for xp from torrentz/mininova make sure u have either bitlord or utorrent installed on ure system 1st when download is done move folder from in downloads to your desktop now open up device manager goto the pci device needing driver should have yellow question mark at it and tell the pc to search your desktop and it should hopefully find it in the folder when done delete folder and make sure your not running utorrent/bitlord as you will be shareing this file with others
Oct 09, 2009 | Computers & Internet
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
E-Machines etower 600is PC Desktop Logo
138 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
