Technics SH8020 graphic eq how do i connect to my amp
My amp is a standard jvc amp but im not sure how i connect
marsrover
  • 682 Answers
SOURCE: technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Posted on Jul 16, 2008
marsrover
  • 682 Answers
SOURCE: How to connect a Technics Graphic Equalizer to a JVC stereo system?
your situation is not so easy to solve but the ideal solution to connect everything to mixer(line in) and connect equalizer to main inserter in mixer(in this you got equalizer work with all media)(check mackie mixer dealer and ask about model have main inserter.
Posted on Jul 19, 2008
marsrover
  • 682 Answers
SOURCE: dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Posted on Nov 11, 2008
  • 61 Answers
SOURCE: How do I up Receiver/EQ/Amp?
In the order you state them.
Receiver, EQ, Amplifier,
These graphic eq's and the amplifiers are pin 2 hot on the XLR by default (which is the norm) unlike some other makes. Handy to know when making up cables from receivers like this.
Posted on Mar 28, 2009
gokomets
  • 120 Answers
SOURCE: eq to receiver
Connect through the tape monitor jacks and if a tape deck is used connect it to the eq! Check your owners manual if you still have it or download one.
Posted on Apr 14, 2010
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
How do i connect my technics su7700 amp to my technics sh8020 equaliser
Like any sound processor, in the tape loop...
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec or Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play or Line-Out.
Feb 15, 2011 | Audio Players & Recorders
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Technics su-a808 amp & sh-ge70 graphic equaliser.
Jun 24, 2008 | Audio Players & Recorders
Connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
May 28, 2008 | Audio Players & Recorders
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
Open Questions:
1,053 people viewed this question
 Grubhead
Grubhead
