Question about Siemens Computers & Internet
Port forwarding on Siemens 5890
Set up port forwarding 5901 to ip 192.168.100.7
SOURCE: How to port forward th 2 wire router from web port 80 and tcp/ip port 6100..?
Hi, Here is a manual explaining how to do it... lorexstore.lorextechnology.com/ pdfs/SG19LD804-161_CLIENT_MANUAL_EN_R2.pdf -
Posted on Aug 04, 2007
  • 55 Answers
SOURCE: static ip address
It is a ADSL Modem. It should have all ports open. In order to set a EXTERNAL static Ip address, you would have to call up your ISP and ask for a static IP address.
Posted on Aug 25, 2007
SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
Posted on Feb 19, 2008
SOURCE: Port Forwarding on Bigpond 2071a
yes u can forward 2071-a open browser and put this in addy bar 10.0.0.138
Posted on Nov 26, 2008
dvancamp
  • 13 Answers
SOURCE: Port forwarding
You have to create an object for your Web server and then set up new rule to forward traffic via port 80 to the newly created object.
Posted on Feb 10, 2009
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Changing NAT setting
You need to do port forwarding. Search for the port number of that specific game and forward it on the router's admin page.
Apr 26, 2009 | Siemens SpeedStream 6300 (33A6300001)...
Wanna open gates from the router SIEMENS 5890
u can use the port forward for forwading ur port if it is blocked.
Jan 07, 2009 | Computers & Internet
Http access
Router cannot forward tcp requests to linux box if it has a http server already running on the same port. Make the router's web server listen on a different port.
May 22, 2008 | Siemens SpeedStream 2604 Router (obss2604...
Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Apr 30, 2008 | Computers & Internet
Unstable PS3 connection
good idea to assign your own ip but no need to use dmz...
do the following:
1. reset your router to factory settings, assign urself an ip address (make sure its out of the scope of the dhcp), no need for dmz
2. enable upnp (thats what ps3 uses)
open these specific ports if u are using firewalls
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
also if u want to make it faster use Port forwarding and then forward the above port to your static ps3 ip address and u will get even lower pings to play games and no lag
cheers
smeags
Feb 27, 2008 | Linksys Wireless-G WRT54GX Router...
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at http://192.168.1.1.
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
Static ip address
Aug 25, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Computers & Internet Logo
535 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
