Try "0000" code? It's default. OR
Service with special service cable and software can reset the code, but don't worry, it won't be expensive, only few bucks
for powering on use ur phone charged for sometime wait for some time after charging and press contiously the power bottone of ur phone untill the phone start fully first it flash a white blank screen and then it start.
after start of phone Please reset your phone setting without data loss it only reset your settings like as ringtones,skins,etc. as defult settings U follow it work Menu>Settings>Initial Setup>Master Reset>"ur secuirty code" It takes sometime and then it free from this problem
try doing a reset settings or master reset on the phone, since this is a device issue if it doesnt work then you will need to get a replacement phone thru your provider
That could be that one of the components on the LCD is going bad. When this happens its always good to do a hard reset, meaning to remove battery give it a few then try to power it up again. If the issue persists i would also try performing a master reset. Make sure that your contacts,pictures and other things are backed up, for a master reset "can" delete and personal content e.g. contacts store on handset memory, pictures, downloaded content. If that fails, and your phone is less than a year old you can contact your provider phones usually come with a one year warranty through manufacturer. They might replace it at, although they might need to do some troubleshooting with you. Which will most likely comprise of what i told you.
my lg's camera started to turn my phone off, i do tech work for a wireless company and when i was trouble shooting my own phone as a test i went to my camera and my screen went blank! i tryed every thing, but the master reset. because my screen is blank i need to know the number i will have to enter to get it reset from the key pad.
Have you tried a Master Reset? If not, it may help, but it WILL ERASE ALL OF YOUR FAVORITES, and may remove anything you have updated. To do a Master Reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but keep pressing the screen until the unit asks if you are sure you want to reset. Press yes. This may help.
