Ariston Technologies AWD 121
Problem for Ariston Technologies AWD 121 (NA)
Ariston (bo 2320 ai uk) built in fridge has ice
By mcgoverntony on Aug 26, 2009
ariston (bo 2320 ai uk) built in fridge has ice build up it should defrost it's self
Comments:
Aug 27, 2009
- hi the coil's and parts are all clean, the only part that has that many wires connected is attached to the compressor. there is no screw turnable seen but a disc which has a wire connected this does not move ether. the only other box like part is inside where light and temp dial is connected?
Solution #1
posted on Aug 26, 2009
Somewhat Helpful)
garing
Rank: Wiz
Rating: 82%, 350 votes
check your coils for dust lint...hair if it is all clean then it must be a defrost problem look for the defrost timer it is a box with 5-6 wires on it and a hole about 1/4 inch with a flat screw in it this box can be anywhere inside or out by compressor or the ceiling of the fridge under a cover or behind the toe kick keep looking all fridges have one it's just hard to find once you find it use a flat screw driver to turn it .....it will only turn one way turn it until you hear it click plug fridge in for 30 minuets you should hear compressor start (you may hear sounds and hopefully you see a glow-watch for it coming from freezer not to worry) if the compressor did not start replace timer ...if there was no glow or sounds like drops of water on a hot stove you will need to let the fridge defrost over night with doors open then take screws out of back panel and remove panel to get to the element and termination switch (the component inline with element)your in it now so go for the works(replace both)
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies AWD 121
Questions and Unsolved Problems for Ariston Technologies AWD 121
Do you recommend Ariston Technologies AWD 121 (NA)?
Answer
Answer
HI, The boiler shows E34 error code, when the plank is removed its working as normal and when... (More)
Answer
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of... (More)
Answer
how do i set my timer for my central heating to come on am and pm
Answer
I had an Ariston range hood which got brittle and then broke apart.It was 60cm wide and I would like... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ariston Technologies AWD 121:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14919
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
