rarity but belt could be stretched does the big pulley turn freely is it tight is the motor tight if everything is tight and spins freely try a new belt
You may have dislodged the suspended innards from shock mounts that keeps some nose from escaping.
I would remove the back panel and inspect the insides to see if one or more corners of the suspended assembly are now out of place.
Fix it yourself, and you do not need to remove the tub. Put the belt around the pulley and pull the tub towards the belt. You may have bought a belt that is too short. But upon a belt breaking they will stretch pretty bad also
this is a common problem as nowadays stretchy belts are used in order to avoid motor adjustment.
fitting requires some brute force. the way i do it is to put the belt on the motor pulley then start it as much as i can on the drum pulley. turn the drum pulley keeping force sideways to push the belt on and as you turn, the belt will go on
