Question about Sony KDS-R50XBR1 50" HDTV
No video or audio for Sony KDS-R50XBR1
I try to turn on the set and the power light goes green like normal but then changes to six flashing red lights with out powering up.
  • 2 more comments
  • mikeyd52 Dec 06, 2007
    ctf1800,
    Thanks for the info and links. They were an eye opener and answer some past questions.
  • mikeyd52 Dec 08, 2007
    Guest,
    Thanks. ctf1800 also led me to the same link and since my original post Sears repair was able to get out sooner than I expected and I was able to know one of my problems was the optical block and they will be replacing it.
  • sernacarlo76 Sep 05, 2008
    green light went on like it was going to turn on but then nothing but a red light flashing with no picture
  • marinoSXRD Oct 17, 2008
    I have the same set and the Power/Standby light is flashing red six times. What is it?
Not confidential anymore.
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Posted on Dec 08, 2007
    President:
  • 4,402 Answers
Http://esupport.sony.com/sxrdsettlement
Otherwise there is a full recall on all 50XBR1's and 60XBR1's for ANY video issue.
But the bullentin I do have on that is Confidential due to the amount of claims SONY could recieve. But here is a sample of the bulletin.
Models: KDSR50XBR1, KDSR60XBR1
Subject: Optical Block: Warranty Policy and Part matrix by serial number.
Resolution: As part of Sony’s commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor) for optical block replacements on the models listed above until October 31, 2008, regardless of purchase date. Authorized servicers should follow the normal process for warranty claims for this issue.
http://www.hdtvoice.com/voice/showthread.php?t=31861
Posted on Dec 05, 2007
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDS-R50XBR1 50" HDTV Logo
497 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
