Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Line down center of page.
I have a line down the center of the page when I copy a document. I have changed the DRUM and also the Ink Cartridge. This line only happens when I copy something myself - not on any incoming faxes. Thanks, Sherrey
  • Sherrey Dec 05, 2007
    THANK YOU, THANK YOU, THANK YOU - PERFECT SOLUTION. YOU SAVED ME A SERVICE CHARGE!! THANKS AGAIN - HAPPY HOLIDAYS.
  • 56 Answers
Hi Sherrey, I think I can help! If you open the ADF cover where you insert your pages to make a copy. You will see a scanner glass about 1/2 inch wide and runs across the width of the printer. You can take a soft towel and some glass cleaner and clean the glass. There will probably be some white build up that looks like white out on the glass just make sure you clean it very well. I hope this helps!!!!
Posted on Dec 05, 2007
When making copies af a document a black line is showing on the bottom of the copied page. How can we fix it.
Clean the document laying flat glass with micro fiber cloth.
Pull out the toner/drum assrmbly and clean the drum with same cloth. Turn the drum using black circular dial on the side and clean it. Do not touch the drum. Also, change the toner cartridge if you have not for long time. This mostly happens when the cartridge is about to run out of toner ink powder.
hope this helps.
Dec 15, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
It say drum end soon and i dont know what this means as i put a new ink cartridge in it and it still keeps coming up the same.
Your unit obviously has a separate drum and toner.
Changing the toner, doesn't change the drum.
You will need to change the drum soon.
Jun 24, 2011 | Brother Office Equipment & Supplies
Have a black line on all my scanned files, runs the length of the page, about 1 1/2 inches from the left edge.
To determine if the vertical lines appearing on your printed documents are related to a printing or scanning issue, print a test page by pressing MENU, 4 (Printer), 2 (Print Options), 3(Test Print) and COLOR START.
If the vertical lines appear on the Test Print continue to Procedure A:Cleaning the Corona Wires Inside the Drum.
If the vertical lines do NOT appear on the Test Print continue to Procedure B: Cleaning the Scanner Glass.
Procedure A: Cleaning the Corona Wires Inside the Drum:
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
A1. Power off the Brother machine using the power switch located on the right side of the machine.
A2. Press down on the front cover release lever and open the front coverby pulling it towards you.
A3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
A4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
A5. Lift the white plastic corona wire cover by lifting the tabs locatedon the right and left side of the cover.
A6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
A7. Close the corona wire cover.
A8. Repeat Steps 5 through 7 to clean each of the remaining three coronawires.
A9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
A10. Push the drum unit back into the machine until it clicks into place.
A11. Close the front door and power on the Brother machine.
A12. Print a test page by pressing Menu, 4 (Printer), 2 (Print Options),3(Test Print) and Color Start.
B1. For safety reasons, power the Brother machine Off using the power switch located on the right side of the machine.
B2. Lift the Document Cover and clean the following with a lint-free cloth moistened with a non-flammable glass cleaner:
a. Run your fingertip over the scanner glass of the flat bed to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris. (Caution! Do notpress down on the glass very hard.)
b. Run your fingertip over the scanner glass on the left to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris.
c. The white plastic pad located on the underside of the Document Cover
d. The white plastic pressure bar located to the left of the white plastic pad.
B3. Close the Document Cover.
B4. Test the machine by making a copy of a blank sheet of paper using the ADF (Automatic Document Feeder) and a copy using the Flat Bed.
a. To make a copy using the ADF, place the document face UP in the ADF, press the COPY mode key located below the LCD display and then COLOR START. If the problem continues,repeat Steps 2b and 2d at least 3 additional times.
b. To make a copy using the flat bed, lift the Document Cover of the flat bed, place the document face down on the scanner glass (make sure the ADF is empty) and close the Document Cover. Press the COPY mode key located below the LCD display and then COLOR START. If the problem continues, repeat Steps 2a and 2c at least 3 additional times.
Oct 29, 2010 | Brother MFC-9440CN Laser Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Black line down the center down the page
If it is a lazer printer a score on the photosensitive drum will leave a black line. Sometimes it is less grevious cace of an accumulation of ink leaving a line around the drum. This can happen when printing many dark background or full bleed copies. These drums are seensitive but can be carefully cleaned. Work away from direct strong light.
Regards
Apeal
Aug 20, 2009 | Canon Office Equipment & Supplies
WHITE LINE DOWN CENTER OF PAGE
I guess that you get a white line when you are printing a document or receiving a fax....
The drum unit is scratched and needs to be replaced. Most of these printers have the drum unit as part of the cartridge; thus replacing the toner should solve your problem.
Jul 07, 2009 | Dell 1600n All-In-One Laser Printer
Lines
I will give you all the reasons I can think of.
1, If the line is only there when running through a document feeder and not there off the glass. The small strip of glass directly under the document feeder is dirty.
2. The drum has a scratch on it, or the cleaning blade is not cleaning the drum properly. Would require that cartridge replacement.
3. The fuser roller may be work in the middle. You would notice some reprinting , or ghost copying if that were bad.
4. Less likely would be some piece of fuzz in the light path, or a small piece of paper or tape in the paper path smearing the ink across the page.
If your machine prints, see if the line is on a print, if its on a print and not on the copy then it is scanner related.
Mar 13, 2008 | Office Equipment & Supplies
My printed and copied pictures have horozontal lines
White lines through copies White lines can appear on a copy in either a horizontal or vertical direction. How the white line appears on the copy will determine the cause and solution. Horizontal lines Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps: 1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below: 1. Verify that there is plain white paper in the Input tray. 2. Press Setup. 3. Press or to select Tools and then press OK. 4. Press or to select Clean Print Cartridge and then press OK. The unit prints a test page. 5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again 2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step. 3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels. 1. Open HP Solution Center. 2. Click Settings. 3. Click Print Settings. 4. Click Printer Toolbox. 5. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab and then click Printer Services button then click the Estimated Ink Levels tab. 6. Replace any ink cartridge that is low on ink. 4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage. 1. Open the front of the unit to access the ink cartridges. 2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process. 3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them. Figure 2: Cleaning the ink cartridge 1 - Clean in the cross-hatched area only 2 - Do not touch the nozzle plate 3 - Clean the copper-colored contacts 4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges. 5. Allow the cartridges to dry before reinserting them. 6. Close the unit, and plug the power cord back in. 7. Print a self-test page to check the results. Follow the steps below to print a self-test page. 1. Press Setup. 2. Press or until Print Report displays and then press OK. 3. Press or until Self-Test Report displays and then press OK. The self-test report prints. 5. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s). Vertical lines Vertical white lines usually indicate the scanner did not calibrate correctly. This can be caused by debris on the scanner glass or white reference pad. Try the following steps: 1. Turn off the HP all-in-one product and unplug the power cord. 2. Open the document cover to access the scanner glass. 3. Using a non abrasive glass cleaner, thoroughly clean the scanner/copier glass, and white lid backing on the inside of the top cover. CAUTION: Spray the cleaner onto the cloth. Never spray fluids directly onto the HP all-in-one product. 4. Plug in the power cord and turn on the HP all-in-one. Let me know what happens, Good Luck, Tim
Mar 14, 2007 | HP PSC 1315 All-In-One InkJet Printer
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
289 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
