Refrigerators Logo
Posted on Aug 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Re Liebherr KTe 1744 fridge: need replacement upper full glass shelf including plastic trim or, if removable, front plastic trim only x 2 no. Where's best place to get?
Anonymous
Level 2:
  • Expert 64 Answers
  • Posted on Aug 26, 2009
Anonymous
Expert
Level 2:
Answers
64
Questions
Helped
31306
Points
140
Have one made at a glass shop and have them temper it
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
2answers
How to install replacement sunroof motor on a 1999 Pontiac grand prix
Important: This sunroof system is timed from the factory in order to allow the actuator to shut off automatically when the sunroof window reaches a certain position. Use extreme care when removing the actuator from the sunroof module. This may cause the timing to be thrown off. This may damage to the sunroof. Anytime the actuator needs to be removed from the module, ensure that the sunroof window is in the fully closed position.
Remove the sunroof window. Refer to Sunroof Glass Panel Replacement .
Slide the sunshade fully rearward. Move the sunroof window to the vent position. Remove the sunroof screws (two on each side). Remove the sunroof window from the module.
Place the sunroof module in the fully closed position. Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior trim.
Tools Required ?€¢
J 38778 Door Trim Pad and Garnish Clip Remover
J 2772-C Headliner Installer
  1. Remove the sunshades. Refer to Sunshade Replacement .
  2. Remove the overhead console, if equipped. Refer to Roof Console Replacement .
  3. Remove the sunshade retainers. Refer to Sunshade Anchor Replacement .
  4. Remove the power sunroof switch, if equipped. Refer to Sunroof Switch Replacement in Roof.
  5. Remove the sunroof trim lace, if equipped. Refer to Sunroof Seal/Molding Replacement in Roof.
  6. Remove the dome light, if equipped.
  7. Remove the coat hooks. Refer to Coat Hook Replacement .
  8. Remove the assist handles. Assist Strap Replacement
  9. Remove the rail lamp. Refer to Roof Side Rail Lamp Replacement in Lighting.
  10. Remove the windshield side garnish molding. Refer to Windshield Pillar Garnish Molding Replacement .
  11. Remove the upper quarter trim panels. Refer to Rear Quarter Upper Trim Panel Replacement .
  12. Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement .
  13. Pull down on the door opening weatherstrip seal on both the front and the rear doors.
  14. Remove the 2 rear retainers (2) using J 38778 Door Trim Pad and Garnish Clip Remover. Disconnect the headliner electric harness at the right side of the rear window shelf. Rotate the right front seatback to a horizontal position. Remove the headliner from the vehicle through the right front door.
Disconnect the electrical connector from the actuator.
Important: Before removing the actuator, ensure that the pins J 41718 are tight and holding the cable.
Thread the J 41718 into the front sunroof window screw hole in order to retain the cable adjustment. Remove the sunroof actuator screws. Remove the sunroof actuator from the module. Did you look for a video on youtube ?
Remove door panel
According with the factory manual...
23 - Body/Door - Front/PANEL, Door Trim/Description
DESCRIPTION
Door trim modules include the hardware, window regulators, latch, remote handle and links, speakers and wiring harness. In addition to providing manufacturing efficiencies, the door modules benefit the customer too. Having all the parts assembled into a module improves build accuracy and fit and finish between the components and trim as a result of greater communication between the release engineers and suppliers.
Lower door trim (from the beltline down) is molded polypropylene. The door trim is two-tone with a darker color matching the instrument panel in the upper third and a lighter shade for the lower two-thirds, including the bolster and substrate.
2. Remove speaker (5),
3. Remove the trim screws (4) from the speaker opening.
4. Remove the trim cap (6) and the screw (1) at the inside handle.
5. Using a trim stick C-4755 or equivalent, remove the outside mirror trim (2).
6. Remove the door glass
7. Disconnect the latch linkages (1 and 2).
8. Remove the latch screws (4).
9. Disconnect main harness connector.
10. Remove screws and separate harness from door
11. Remove three upper bolts (1).
12. Lift the module (1) up off of the four trim hooks (3) and the lower regulator screws (4).
13. Pull the front of the trim module (1) out from the door and forward to remove the latch.
Check attached images.
Hope helps.
2a275dbc-6a63-4b14-990e-f2f7a7d43762.jpg e1e59ca6-c374-4db0-b4e5-45ecb230588c.jpg
4helpful
3answers
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Need to replace sunroof..
you need to replace glass or is it leaking if leaking then you have to remove upper seat belt covers pop off remove bolt 14mm and the trims on upper pillars pry off carefully held in by clips remove covers on interior light at front where sunroof switches are there are screws by bulbs disconnect connector remove center light cover and screws disconnect connector with clean hands remove rbber trim around sunroof opening and plastic cover on each side of sunroof glass held on with plastic screw clips then remove four 10mm nuts lift sunroof glass out of car remove cover and screws from rearview mirror all plastic trims around headliner move pass seat forward most and flip back rest all way down roll pass window fully down then slide headliner out of car now you can remove electrical connectors and remove water flow hoses from sunroof unit remove 8 12mm nuts holding frame to roof remove through door you will see the track sunroof slides on remove nuts along problem is silicone between track and frame is deteriorated lift track clean replace silicone reattach frame to roof dont put trims or liner in till test connect switches and glass to frame make sure sunroof works and closes fully then go through car wash to see if leak is fixed
Wher can i get parts for my liebherr premium ctnes 4753 nofrost
try using frosted glass(toughened)more permanent,use a plastic shelf as a template.....
Replacing brake light above trunk on 2006 chrysler
This is quite a process....
Removal
1) Disconnect and isolate the negative battery cable.
2) Remove the rear shelf trim panel.
3) Disconnect the CHMSL electrical connector (1).
4) Remove the two mounting fasteners (3) to the CHMSL (2).
Installation is opposite of removal.
Rear shelf trim panel
Removal
1) Disconnect and isolate the battery negative cable.
2) Remover the right and left lower and upper C-pillar trim.
3) Remove the nut that secures the center rear seat belt lower anchor to the stud on the floor panel and feed the seat belt webbing back through the opening in the top of the rear shelf panel trim (2) to the retractor.
4) Remove the push-pin fastener (1) that secures the trim (2) to the rear shelf panel.
5) Slide the trim forward to disengage the S-clip that secures the underside of the trim to the to the center of the shelf panel.
6) Remove the trim from the rear shelf panel.
Installation
1) Position the trim (2) onto the rear shelf panel(3).
2) Slide the rear edge of the trim rearward to engage the lens bezel of the center high-mounted stop lamp and far enough to engage the S-clip that secures the underside of the trim to the center of the shelf panel.
3) Install the push-pin fastener (1) that secures the trim to the rear shelf panel.
4) Pull the center rear seat belt lower anchor and belt webbing from the retractor through the opening the the top of the rear shelf panel trim and back down to the stud on the floor panel.
5) Install and tighten the nut that secures the seat belt lower anchor to the stud on the floor panel. Tighten the nut to 34 N m (25 ft. lbs.).
6) Reinstall the right and left upper and lower C-pillar trim.
7) Connect the battery negative cable.
C-pillar trim removal
Seat removal
Hope this all gets it done for you........
I broke the glass over the vegetable drawers in the Liebherr CS 1901 refrigerator and need to replace it?
You can order a new shelf from your dealer, or you can replace the shelf with a piece of tempered glass from a glass supplier, or even use plexiglass.
Best regards, --W/D--
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
2answers
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Top Liebherr Refrigerators Experts
ZJ Limited
ZJ Limited
Paul Carew
Daniel Blask
Daniel Blask
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
