Question about Zanussi FJS1225W Front Load Washer
Error code e30
Zanussi zwf 1230 w washing machine took out the pump to clean as it was blocked put back in and since then it keeps flashing and bleeping error e30 any ideal
    New Friend:
My washing machine is flashinf e 30 what does this mean?
Posted on Apr 24, 2013
  • 1,294 Answers
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Posted on Jan 12, 2008
E20 on a zwf1430w washing machine what does this mean
try this:
Mar 08, 2015 | Zanussi Washing Machines
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Zanussi screen flashes e.s.o
Zanussi & AEG
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Washing Machines
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
Zwf 1631 w
Have you took the front cover off and looked for the strainer which is located before the water pump. I have seen many of them plugged tightly, causing the water not to drain. Look inside the owners manual that came with the machine. It also should give you some things to check that would cause the code E20 to keep flashing. Hope this helps.
May 09, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
778 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
