Question about OKIPAGE 10ex Led Printer
I get a message of toner empty on my Okipage 10ex.
Installed new toner cartridge, but get same message.
    Habit-Forming:
  • 40 Answers
You need to reset the toner count using the support software that comes with your printer (2 cds come with printer -1 driver cd and one with supplementery software)
Hope this helps
Dezzi
Posted on Jan 09, 2008
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
Black cartridge error
First, check to see that a toner cartridge is in fact installed.
Open the toner access panel and remove the cartridge.
Check to see if it is indicating that it is empty. If so, replace the toner cartridge and wait for the error message to clear as the machine prepares the new cartridge for printing.
Dec 20, 2012 | Lexmark X4650 InkJet Printer
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
I have a 10 ex laser printer from okidata. the problem is it prints lite on the right hand side (about 2 inches of the whole paper) would this be the drum? thanks
This is sometimes just the toner not being even in the cartridge. It can also be a problem with the image drum or fuse wire unit.
If you take the toner cartridge out and gent shake it side to side this will redistribute the toner in the cartridge. Put it back in and do a test print to see if that fixed your problem This should only happen when the toner gets low. You can get this from moving the printer printing most things along one side and other pretty normal stuff.
If after this the image is still light on the one side then it can a problem with the image drum or fuse wire. they are just as easy to replace as the toner unit but tend to be worth more. The wire is not that bad but still can be a few $$ and is rarely the problem. If it looks like the problem is in the image drum then I'd check out replacement cost of a laser printer. There are some pretty capable printers selling for pretty cheap these days. An image drum is worth about $125 and up and the fuse kit about $120
Aug 22, 2009 | OKIPAGE 10ex Led Printer
Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Jun 18, 2009 | Ricoh FAX2210L Plain Paper Laser
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Toner Cartridge empty
does the display come up as "toner empty x"? what is the last character after the toner empty ?
where x is:
c=cyan= 6,600 pages
m=magenta=6,600 pages
y=yellow=6,600 pages
k=black=10,000 pages
Jan 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Message showing toner empty with the new toner cartridge
Please clarify, you're saying copier and toner problem but it's showing a typewriter which uses a ribbon ???
Oct 23, 2008 | Olivetti MS25 Typewriter
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
OKIPAGE 10ex Led Printer Logo
122 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
