Question about Thermador Ovens
Thermador stay hot oven model #SHO 18G
I need to replace this oven or at least replace the glass in the unit. We are doing some remodeling and I dropped it and broke the glass and bent the unit a bit. At the same time I dropped the oven door for the regular oven. Some of the plastic chipped off above the door handle. The glass didn't break on this part. These ovens are about 22 years old. Hope you can help!
SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 Fax 01628 776345 - Spares Email is
Posted on Apr 14, 2008
SOURCE: top oven front glass broken want replacement
Posted on Oct 08, 2008
  • 17 Answers
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts -
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
Dec 19, 2015 | Thermador C272 Electric Double Oven
Thermador oven preheat light comes back on during baking session. Oven doesn't stay hot enough to finish cooking food.
Get it repaired from authorised personal. Seems sensor elements has gone down or programming chip is malfuctioning.
Oct 05, 2014 | Thermador Ovens
I have broken the outer glass on one of the doors on a thermador SC302TB oven. Is replacing the glass something that a handy homeowner could do?
Yes. replacing the over door glass is no more difficult than removing a few screws, inserting the new glass and reattaching the screws.
That link will take you to a detailed image of the door as well as where you can order a replacement.
Hope this helps.
Sep 06, 2011 | Thermador SC302T Electric Double Oven
Inside glass on door cracked how do I take door abort and put in glass.
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
Jan 22, 2011 | Thermador C301U Electric Single Oven
The glass outer glass on my oven window broke can it be repaired? It's a Thermador Model# CT227NPRS Serial# 98020093
Jan 05, 2011 | Ovens
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
Mar 31, 2010 | Thermador C302U Electric Double Oven
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
Oct 23, 2008 | Thermador Ovens
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
70 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
