Question about Gigabyte GA-7VAXP Ultra Motherboard
No power up
I have a gigabyte boardGA-7VRXP and when i plug the power supply in and power the computer up the fan spins for 1 second then stops the bios light stays on but there is only my power supply and switch plugged onto my board plzzzzzzzz help
  • brierste Jan 05, 2008
    already tried that i have stripped it down putting piece in by piece and still getting the same problem could it be that my proccessor maybe on its way out or even the board
  • nopro May 13, 2008
    I have a GA-7VA rev.1.0 board. I also have the same exact problem. I left the computer on overnight and in the morning everything was frozen...no cursor, no keyboard function, just the desktop. I turned it off and then on and nothing. Fan spins for a fraction of a second then nothing. light on MB remains on. Removed power from each piece of hardware; removed each PC card, substituted ram, reset heat sink and fan with new silver oxide. No evidence of burn. Installed spare power supply (known good). I have no way to substitute mobo nor processor. I'm thinking I got hit by a voltage spike. This computer was the only one not protected UPS backup. Where can I find another mobo-complete?
    Scholar:
  • 131 Answers
Re- assemble the processor unit and try. then check your ram is installed correctly and firmly. Try it out with different ram modules. If it work on other modules, Then you have a bad ram.
Posted on Jan 03, 2008
  • M Karthikeyan
    M Karthikeyan Jan 05, 2008
    Now you have just two options, one check your processor on another board that supports it, two check your mb with a working processor(you know the processor is working condition).
    now you will get to know which one is bad. then you have to get it repaired or replace it with a new one.
    POST me with your results.
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
My gigabyte GA-G31m-s2L motherboard has while i am switchon the board CPU fan working but no other response happen in my monitor please give me troubleshooting method so as to avoid to buy new...
First thing when diagnosing a desktop computer problem, is check the Power Supply.
Really.
A Power Supply with a weak voltage power rail, can also emulate software problems.
(Emulate software problems; The bad hardware (Power Supply), can also make it seem like it is a software problem. It isn't. It's a hardware problem -> Power Supply )
1) Is your computer dirty inside? This will make the computer not work, and also 'kills' Power Supply's.
They overheat, and components inside the Power Supply fail.
(Go bad)
Know this;
1) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Gigabyte GA-G31M-S2L?
http://www.gigabyte.com/products/product-page.aspx?pid=2693#ov
LGA 775 processor socket, and an Intel G31 motherboard chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to G31 in the left column.
Also go back to the Gigabyte Support page.
Click on the Support & Downloads tab.
(Overview / Specification / Support & Downloads / FAQ / etc)
Click on the blue - CPU Support List tab.
(CPU Support List / Memory Support List / Accessory )
Your motherboard can support Processors that use 35 Watts all the way up to 135 Watts.
Point?
If you have a Power Supply with a weak voltage power rail; you may see LED lights light, and fans spin; but there will NOT be enough power to turn the Processor ON.
Do you have a multimeter to test the 3 main voltages?
OR;
Do you have a KNOWN to be good, Compatible power supply; to use for a temporary test unit?
Also;
When working on your computer FOLLOW Anti-Static Precautions.
If you are not aware of what Anti-Static Precautions are, please post back in a Comment.
DO NOT work on your computer until you do.
Remove all Ram Memory modules. ('Stick')
Clean the gold plated contact pins with a pencil eraser.
If using an eraser on the end of a pencil; and not a solid eraser; refrain from letting the metal band of the pencil; touch the gold plated contact pins.
Rub across all gold plated contact pins, and up, and down. BOTH sides.
When finished use air to remove the eraser dust.
You can use a can of compressed air for computers, or air pressure from your mouth will be sufficient.
Handle the Ram Memory module by the BODY.
The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins.
The Body is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Reinstall the Ram Memory module/s. Plug the computer back into power. WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 02, 2013 | Gigabyte GA-G31M-ES2L Motherboard
I get nothing except the fans running for about one second. No lights, no beeps, no noise. No nothing. If I push the button again I don't even get the fans to run. If I wait I get the fans again f
Chances are that your power supply is toast.
Although you could try removing either one of your rams (if you have 2), and unplugging any optional device plugged onto the motherboard (Hard drive, dvd player)
In the worse case, your motherboard could be broken and need to be replaced.
Did anything particular happen before it stopped powering up?
Jul 05, 2012 | Computers & Internet
When powered on unit only beeps. continuous beeping- approx 1 every two seconds. nothing boots up at all, only beeps! Tried removing memory thinking it may be a memory issue but that was not the issue!...
Hi
If you have a Gigabyte MoBo then the CPU fan has stopped running.
Open the casing side cover and see if the CPU cooling fan is running or not.
If it does not run, the go into BIOS and disable "HDD S.M.A.R.T. Capability" in Advanced Bios Features
also set "CPU smart fan control" to disable in PC Health Status
OR
This may be a power supply problem.
The voltages of the power supply are going out of limits.
change the power supply and see.
May 20, 2011 | HP Pavilion Media Center a1510n PC...
My cpu fan is not working in my Gigabyte GA-8ST667 system can anyone tell me why am sure the cpu fan is good
Hello elscomputers: If you are sure that there is no other issue with the motherboard -- It was working before the CPU Fan/Heatsink stopped working. Other than making sure that it is correctly connected as shown below -- attached to Pin 1 with all three pins connected (not off to the side by one pin), you can assume it's bad (they do wear out). The cost of a new cooler is pretty minimal and I would just replace it.
Good Luck and Thanks for inquiring at Fix Ya.
Mikeywaf
Mar 22, 2011 | Gigabyte GA-8ST667-L Motherboard
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
Put an extra hd , now cpu fan spins and stops after 1 sec
Disconnect the data-cable and power-cable from the extra hard-drive, and try again. If the problem is the same, then the extra hard-drive, by itself, is not the problem. Borrow a power-supply, and connect it to the motherboard, and see if the alternate power-supply solves the problem.
Oct 09, 2009 | Computers & Internet
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Gigabyte GA-7VAXP Ultra Motherboard Logo
160 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
