Question about Canon EOS-10D Digital Camera
Err 99 Hi,My Canon lens work fine, but as soon as I put on my Sigma 70-300mmAPO macro a/f lens all goes dead & the top panel reads ERR 99, tried all the usual remedies ie change battery, cf card clean contacts..none work !!...do you have a remedy please...john
Hi there.
Canon 10D is old by now, the error 99 is mostly for the shutter mechanism. is rround $200 to chang it.
Posted on Jun 07, 2008
    Scholar:
  • 48 Answers
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Posted on Dec 04, 2007
DS 126151 error
What kind of error? Err 99?
You mention DS 126151, that's the model number. This camera is mostly know as Canon EOS Rebel XTi? Also known as the EOS 400D or EOS Kiss Digital X.
If you are getting a Err 99 while shooting, try any other lens that will fit on your Canon. In most cases the aperture will become defect in these lenses. Not worth repairing if you ask me. One thing you could do, is shoot only at its maximum aperture. So that'll be F4.0 at 70mm and F5.6 at 300mm. That might work, but that might not be suitable in every situation.
Dec 30, 2013 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Hi sometimes it takes a picture with no problem but sometimes I get err 99 or err 01. Any ideas?
Hi! Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for choosing Fixya!
Feb 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 UC Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts but still get...
From working with third party lenses in the past what I've found is that Canon doesn't give up the "chip" technology so the older lens can not talk to the newer cameras. I suspect that Canon does this to promote their lenses over the competition. You might be able to send the lens to Sigma and have them re-chip it and have a great lens again.
Dec 26, 2010 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Hey! I purchased a Sigma lens 70-300mm macro ____ and after I've attached it to my Canon 450D a take one or several pictures I get the "Err 01" problem, that "the communication between the camera and...
According to Sigma, your lens should be fully compatible with your camera although there will be the usual 1.6x crop factor as the lens is designed for a full frame sensor. This would not cause your Err 01 fault though so you should return the lens to your dealer for refund or exchange. Failing that, consider claiming on Sigma's one year international warranty. The warranty is ONLY valid if your lens was supplied with the Sigma Warranty card. All new Sigma lenses supplied through official resellers include the Warranty Card. You can find more details about where to send your lens for a warranty repair by clicking here.
Good luck, and please take a moment to rate my reply.
Sep 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 DL Hyperzoom macro Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts...
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
May 19, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
My Canon is displaying - Err 99 what should I do?
See if Sigma has any updated advice on this. Otherwise, I don't mean to sound rude or harsh, but unfortunately you may be out of luck with the compatibility...you will need to get a Canon lens. Error 99 is just a communication error and cleaning the contacts is about all you can really do so if that hasn't worked...I'm sure this is not the news you want to hear, but contact Sigma if you haven't already and see what they say.
Take care!
May 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99 msg on new canon
there is a defective flexwire inside the lens or unfortunately the opening or fstops motor is defective. flexwire is easy to repair but a replacement motor is not available or hard to find, (the magnet inside the motor is slowly disintegrating causing it to stall)
Dec 31, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS-10D Digital Camera Logo
187 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
