Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Older jenn air wall unit oven / turn knob
The Meal temperature buzzer will trigger as soon as we put oven on bake.
The buzzer will stay on and the oven will not heat. We rent the home and have zero info on oven. I called Jenn Air...because it is an older model they cannot help.
I am at jason.straw@fritolay.com
this is my first time using your site
  • Team Canada Jan 11, 2008
    I have a Jenn-air W146 with the same problem , tried resetting as per teck's request, (breaker off for 1/2 hr.). No help. Any help would be appreciated
  • CBILL4MAR Nov 23, 2008
    my Jenn Air wall oven purchased in 1987, Model #W-221 recently started to buzz when I turn oven on, Meal Temp light goes on, no heat, and continuous buzzing; only way to stop it by turning all dials off.
    President:
  • 1,314 Answers
Is it showing a code like f8 or any f code
Posted on Dec 29, 2007
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My Jenn Air oven W27200B displays F2 error any solutions? Also one of the burners would hang- one worked and the other didnt.
HI. this is a failed oven temp sensor or relay board.
Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
Ohm test the oven temperature sensor, if OK, change power relay board.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Yes, I just had same problem. The probe receptical is on the right inside wall of the oven. A little flapper door is secured by a single phillips screw. Remove this screw and the flapper door. Gently remove the receptical and its attached cable adapter. With your screw driver short the connector extension to the housing, just as the probe would. This should reset the meal temperature sensor. Try the bake and problem should be gone. If not permanently short this connection with a wire. You won't be able to use your probe, but the oven will work.
Feb 23, 2009 | Ovens
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
274 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
