Question about Panasonic PV-DV103 Mini DV Digital Camcorder
Cant connect to PC
I have a firewire cable plug it in to the camcorder plug the other end into my sony vaio running XP SP2. I keep getting a windows message asking for drivers. Where do i get the driver or how can i get this to work with my sony vaio?
I have the same problem. Windows indicates that it sees the camera and for some unknown reason to me it refuses to install the drivers.
Posted on Dec 29, 2007
    Scholar:
  • 48 Answers
Here is Panasonic's support site. You should be able to find it there.
Posted on Dec 04, 2007
SONY DSR PD 170 OR 170P IS THE CAMERA MODEL AND LAPTOP IS SONY VAIO VPCEG18FG. The camera has a DV firewire port and lap top has only 3 usb ports. I tried connecting it with a cable that ha s firewire...
This Camcorder does not support USB streaming with the Windows 7 Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.The Firewire to USB cable won't work with your camcorder,you will always end up with this error.
Click the link below for the instruction to transfer the video to the Computer using i.LINK cable.
>> http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You Sony vaio laptop doesn't have firewire ports ,in this case you will need to purchase and install an firewire card ..>>
see link >>
http://www.ramelectronics.net/computer-parts/computer-accessories/firewire-i-link/firewire-cards/29972/prod29972.html
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Please let me know if you need further assistance on this issue .
Nov 13, 2011 | Video Cameras
Hi there cannot connect i link to my pc no connection on my pc any advice would help
Usually what you would do is buy a IEEE-1394 interface card and install it in your PC in an available slot on the motherboard. You can buy these for less than $20 and with a little tech knowledge about PCs many people can install the card themselves. The IEEE-1394 is called i.Link by Sony. If you are running Windows XP, or Vista, the drivers are already installed. Reboot PC and the new card should be recognized. Use the 4-pin to 4-pin firewire cable to connect camcorder to PC. You will need software to capture your video which should have been supplied by Sony with your camera. For Windows 7, you need to install LIVE Photo Gallery. Your camcorder was setup to work with Windows XP so an alternative may be to just find a friend with an older PC with a firewire card already installed running Windows XP. I just did this very same thing on my PC and it worked. Got the firewire card from Amazon.com for $3.95 VIA brand from Taiwan. I used Windows Movie Maker to capture video. Sony also sells a stand-alone DVD recorder which connects to a camcorder and requires no computer to create DVDs of your video.
Mar 18, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
The pc doesnt seems to detect my cam like it needs a driver or something i plug the firewire and nothing happens
This can be caused by several things. One common problem is a faulty cable. If you have another Firewire/1394 cable, try that.
A second problem is using the wrong cable. I don't remember if the VX2000 takes still photos, but if it does, many Sony camcorders have a USB connection for transferring the still photos. However, the USB connection will NOT transfer video.
A third problem is drivers. This is usually only a problem on older Windows computers. By older, I mean Windows 98, Windows ME, and the first generation of Windows XP (the first generation is "service pack 1"). However, if you have Windows XP and have done updates, then you probably have the correct driver. If you haven't done updates, then you need to get the update for Firewire/1394.
Finally, if you haven't tried re-booting the computer, that very often is needed -- especially with older (more than five years old) -- computers. Even with modern computers, the computer will often get into a state where it won't recognize peripherals. I recommend shutting off the computer completely, disconnecting the camcorder, and then turning off the camcorder. Then, re-start the computer and after it has booted, turn on the camcorder and after it is on, connect the Firewire/1394 cable between the camcorder and the computer.
Hopefully the camcorder connector is OK. I have broken several Sony Firewire connectors, and it costs about $300 to have them repaired.
Jan 14, 2011 | Sony DCR-VX2000 Mini DV Digital Camcorder
Cannot download video, only Card pictures
I do not know MACs, but a standard 4-pin to 6-pin firewire (IEEE1394) is needed. On Windows XP, plug it in, run Windows Movemaker and you are good to go. By the way, a "DV cable" is a firewire cable.
If your MAC cannot "see" your camcorder, try another firewire device to see if your MAC is the culprit, or drag your camcorder and firewire cable to a friend's PC running Windows XP and see if it works.
May 27, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Can not connect mini dv camcorder to sony vaio laptop
there are many post on various sites that state the same as you ihave the same prob with a sony which i paid £999,00 for and it wont connect i have been researching this problem for months on and of and cannot get any further, what may help you is some information that i have discovered , there are diffrent vers of firwire difrent baud rates this could be one reason for non detection ms sp1 has a diffrent ver to sp2 it is not easy to reinstall sp1 1394 as you need to diable cabbinet files to stop the reloading of the deleted sp2 speed 1394,ther are a few hotfixes avilable from ms on xp not suer about vista also if you plug a faster 1394 device into your machine it could diasble the slower ones , and now for the the killer any manufactur that incorporates 1394 in ther package has to purchase an extremly expensive license and microsoft are heavy into the development of usb stuf and are not concentrating on 1394 hence very little or no support, the only thing you could try is download virtual pc free from ms download site and install the op sys that pertains to the age of the cam good luck
Nov 12, 2008 | Sony DCR-TRV50E Mini DV Digital Camcorder
Panasonic NV-GS70 lost cd installer
Hi, I purchsed Panasonic NV GS-70 in 2004 and facing the same problem in transferring videos to computer. I tried for firewire cable option as well, but the camcorder does not have a firewire port.
Can anyone suggest what kind of firewire cable to be used for it.
Feb 11, 2008 | Panasonic NV-GS70 Mini DV Digital...
Windows Xp Sp2 does not detect my handycam
send the camera to a sony authorized ( only ) service center - the firewire chip may ? be damaged and can not be repaired in the field ; - - ebay may be next best option ( newer model ) ;
Jul 24, 2007 | Sony DCR-HC38 Mini DV Digital Camcorder
Sony dcr-dvd201 unable to connect via usb to xp pro computer
I've learned my lesson here. Firewire and maybe WinDV is what I setup all the time now.
Sep 14, 2005 | Sony Handycam DCR-DVD201 DVD Camcorder
Help loading video to computer
A problem in the Fire wire connections would presumably affect the quality in a quite severe way: you would get large blocks of wrong color or misplaced DCT blocks, the capture would fail altogether from time to time, or something like that. Check the plug in!! Daniel
Sep 13, 2005 | Sony Handycam DCR-HC20 Mini DV Digital...
Panasonic PV-DV103 Mini DV Digital Camcorder Logo
160 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
