Sony evo 9850 error code 20
Sirs: The tape loads into the 9850 unit. The tape loads around the drum. Then when play is pushed, the error code come up with # 20. Can you help me with this problem. I am an electronic technician of many years and have acces to scopes and meters. If you can down load a partial schematic as to the area of interest, it would be very much appreciated. Joe Wagner @ MID-CO A/V. Cell 612 720 2011. Thanks for the help. MY email is joe@midcoav.com at work and joe.wagner@comcast.net at my home hoby shop.
  • joemidco Jan 28, 2008
    Dear Wiz: Do you have any trouble shooting porcedure for this problem? I'm not understanding your approach to my problem. Do you just look on the internet, or are there technicians that can provide a trouble shooting procedure. Thanks, Joe Wagner
    Dear Early: I have checked all the caps on that board, and they all check to be in excelent condition on my Sencore capacity tester. I need more than a shot gun approach to this problem. Thanks, Joe Wagner
    Novelist:
  • 167 Answers
From what i've read an Error-20 on a Sony BSP deck is a tape transport problem. Someone with the same error code (on a BSP model) said the actual tape loading mechanism was bad and they had to replace the hardware inside the machine that loads and ejects the cassette.
Posted on Jan 23, 2008
  • Steve Stonebraker
    Steve Stonebraker Jan 23, 2008
    This is all i could find..
    These people are saying error code 20 means:
    "tape feed error"
    "error 20 message is related to four electrolytic capacitors loacted on a small board on the interior left side next to the tape tray. You can remove and replace these"
    Here are links to these people discussing that error code:
    link1
    link2
  • 871 Answers
Hi, ive searched the internet but sad to say that i havent found any scematics for the evo 9850. there are also lots of other people having the same problem. i will continue to search and if i ever find a scematic relating to your query, ill post it right away.
  • earl norman llanera
    earl norman llanera Jan 23, 2008
    hi again,
    ive read this site which had this exact problem and what they did is completely dissassemble the part of the tape deck. once it is faulty, it may spread to other parts of your recorder. so in mind, this is your only solution.
    hope this helps. those errors codes were #20 and #90.
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
C:31:41 sony errors
Error code 31:41 indicates a fault in the tape transport system can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a dislodged pinch roller or a defective clutch in the take-up spool and will require disassembling the camera to repair. This can usually be done fairly inexpensively. However, it's not a really user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 04, 2011 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
Sony EVO 9850 Hi-8 editing deck is show an "Error 90" message. What is the problem?
Error 90 is a communication error between the SY board and the KY board. Possible loose cable or bad electrolytic capacitor(s).
Dec 07, 2009 | Sony EVO-9800A Hi8 VCR
When tape is inserted the unit starts beeping and I have to eject tape. Tapes will not play, rewind, fast forward or record? How can I fix this?
The beeping indicates that an error has occurred and that the unit has been disabled because operation could damage the unit further. To determine what the problem is- Turn unit off. While holding the STOP button, turn back on and continue to hold the button for 8 sec, then let go. Press display and you will get an error code on the monitor, for instance, C:21:00 error code (the most common code I get) indicates a condensation problem. If this is the code you get then leave the unit open in a dry place for 24 hours or so, and it should dry out the dew sensor and clear the code. The unit will hold up to 6 error codes in the order that they occur, rotate the wheel to cycle through the codes. Codes are displayed as - C:XX:XX. If you get a code other than C:21:00, then google the code,(Sony C:XX:XX) and the description will probably come up. Good luck.
Jun 28, 2009 | Sony EVO-250 Hi8 VCR
Sony EVO 9850 error messages
Hi, Please contact me at TRANS-AUCTION@COMCAST.NEt for solution. Thanks
Jan 04, 2009 | Hitachi VTFX65SK S-VHS VCR
Sony evo-9850
The electrolytic capacitors are dried out.
Aug 05, 2008 | Hitachi VTFX65SK S-VHS VCR
Sony TRV460 error code C31:22
Manual says probably condensation - see page 121
Dec 11, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
Televison & Video Logo
2,226 people viewed this question
Top Televison & Video Experts
