Question about Canon EOS 400D / Rebel XTi Digital Camera
Error Code 05
When attempting to shoot using auto flash, I'm getting an error code (number changes but says the same thing): The built-in flash's auto pop-up was obstructed.
I've tried turning the camera on and off as it suggests. Sometimes it solves the problem - sometimes it doesn't. Camera is only a year old and is taken well care of. Help!!!???
  • Diamond Gal Dec 04, 2007
    Thanks, J! Actually, my menu doesn't display the firmware version . . . ? maybe I need some updates afterall? I researched in my manual - and apparently because I was attempting to shoot a micro shot - I needed to wait a little for things to load properly. In my manual it shows what you get in Menu - one option is Set-up 1, the other is Set-up 2. #2 shows the firmware info, my camera shows the Set up 1 display. Not sure what this means. Do you suppose this means I can't update the firmware? I was finally able to take the photo I wanted - but I'm more than curious about these other issues.
    Problem Solver:
  • 8 Answers
I do not think that it is a firmware issue. I had similar issue with the pop up flash (see here: http://www.youtube.com/watch?v=n5uAv1GcPJ4) and eventually I had to send it to the Service center. First they sent it back to me after cleaning the pop up flash assembly, which worked okay for a week. When it begin to happen again, I had send it again and this time they changed the assembly. Did not see the same problem again.
Posted on Mar 28, 2008
    Scholar:
  • 48 Answers
Just because you've turned the camera off/on, doesn't mean it's been reset. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Canon's website and look for firmware updates. Download and install them.
Err 05 is when the internal flash is obstructed or the camera doesn't get an reply that the flash open sucessfuly. That should be covered in warranty if its an faulty "pop up flash." Call Canon at 1-800-OK-Canon or Email them at: https://consumer.usa.canon.com/ir/controller?act=SupportMailerAct&fcategoryid=215&modelid=9430
Talk to them and they will give you a more in depth stuff.
J. DeRuvo
Digital Camera HQ
Posted on Dec 04, 2007
When I try to take a flash photo I hear a repeated click followed by an 05 error code saying 'the built-in flash's auto pop-up was obstructed.' As as I can see, nothing is obstructing it. I opened the...
This is a mechanical problem probably due to some sand or such material preventing the smooth opening. Try cleaning the open flash hinges with a cloth or brush. Apply a compressed-air can spray and/or a vacuum cleaner nozzle to the area. This happened to me with the Canon Rebel model. Google for the problem specific to your camera model for other solution.
Please rate Fixya answers.
Apr 26, 2011 | Cameras
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 | Ovens
"Error 05 The built in
This could happen when the surrounding temperature is too cold. The camera uses a spring to pop up the flash. If the oil around the spring freezes, the flash will not pop up at all.
The other thought is about the spring itself. if the spring losses, it will cause the flash not pop up again.
If those are not the issues, you may want to bring it to technical support.
Dec 07, 2010 | Cameras
Nikon error code R19
R19 is NOT an error code. The "R<number>" is the number of pictures that may be taken (and stored on the camera's built-in, non-removable, high speed memory) before the camera must move the images to the removable memory card.
If you take a number of pictures in rapid succession, the R19 will decrease to R18, R17, R16 etc. If you shoot all the way to R1, you won't be able to shoot again until the camera is allowed to move the images to the removable memory card. If you don't take pictures in rapid fire mode - the R19 will probably not change as the camera is transferring between your shots.
I hope this was very helpful.
Sep 05, 2010 | Nikon D70s Digital Camera
I get a flashing E-1 error code
I keep getting the flashing E-1 error code...
In the manuel for trouble shoot I do what it ask and there's no change. It will run for 2 or 3 minutes then just start flashing " E - 1" code. Need help Please.
Jun 08, 2010 | Whirlpool GEW9200L Electric Dryer
Battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
May 29, 2009 | 2007 Honda Accord Sedan
The flash on my Canon EOS 400D won't work
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
I have a canon 400d eos digital camara, and when i try to use an error message is displayed error 05 the built in flashes auto pop up was obstructed i have attempted to turn off and on without success...
There is a little switch that tells the camera if the flash is up or down. if your flash is up and you get this message then the switch is eather damaged, a tab is broke or the mainboard is acting up. Thing are a pain let me know if I can help you any further. Hope this helps
Jul 03, 2008 | Canon Cameras
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
769 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
