Question about Kenmore 33169 Gas Single Oven
Tin foil melted in my oven.
Tin foil melted in the bottom of my new kenmore oven. How do I remove it?
  • dam55721 Dec 23, 2008
    Hello Floppy~
    I have the same problem..
    My stove has not coil in the bottom (which is why we bought it)
    and silly me the day we moved in I place tin foil on the bottom of the stove to catch any pizza particles~ I still can't get mine off and it's been 3.5 years~ have you found anything that has helped you yet?
  • 53 Answers
Hi floppy,
if you can't scrape most of it off with a plastic scraper, you may have to buy a new bottom pan. if you can get most of it off it should be ok to use. also if you have propane gas make sure your stove was converted properly.
Posted on Mar 21, 2008
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Tin foil melted and stuck to bottom of the oven of a Kenmorestove
It is safe.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 07, 2010 | Kenmore 33169 Gas Single Oven
Some aluminum foil melted onto the bottom of my Kenmore Elite oven, which happens to have a hidden bake element. I happened to catch that this was happening to remove most of the piece of foil, however,...
Don't use self clean. Get some easy off oven cleaner. Self clean gets too hot and ruins expensive delicate electronics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2010 | Ovens
I have a Kenmore self cleaning oven with foil liner burned on!
Hi Leia, Unfortunately, the aluminum actually melted and adhered. The only perfect fix is to buy a new bottom piece for the oven, it costs about $30.00 and it is very easy to remove the old and install the new. Just a few screws.
You can get the part directly from sears by going to sears.com
May 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Melted tin foil on oven bottom
in your owners manuel is stated to not put tin foil on the bottom of the oven.. depending on your model you may be able to replace the bottom panel.. however you can still use the oven without any problems.
Jan 20, 2009 | Kenmore 30169 Electric Single Oven
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Kenmore 33169 Gas Single Oven Logo
576 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
