Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
How to Install an Ice Maker
I have a Kenmore refrigerator into which I want to install an ice maker. It has never had an ice maker in it previously. A plumber is coming to install the water line. I'd like to install the ice maker myself. Do you have information available about how to do that? (The instructions that came wth the ice maker left a lot to be desired.) Thank you.
SOURCE: Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Posted on Aug 14, 2007
SOURCE: Ice maker
I believe the tube that pours water into the icemaker tray is clogged with frozen water and can not fill the tray and your fridge can not make ice. You have to unplug your fridge and let the tube to defrost. It is a long tube (about 1.5 foot) and using a blow dryer may not do the job. You can unscrew the the gray plastic cover at the back of the fridge and pull out the tube and let it defrost and then put it back.
Posted on Apr 26, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck
Posted on Apr 30, 2008
  • 210 Answers
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Posted on Jun 03, 2008
SOURCE: Refrigerator Ice maker not working
i need an answer to this same question
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: Brand new Kenmore refrigerator, ice maker does not work
According to the manufacture, you must wait 24hrs to reap the benefits of the automatic ice maker. I was helping a friend the other day install a water line to a side by side unit that had been running for well over a week and after turning the water on we got no ice. We contacted the manufacture and they said "there is a 24hr waiting period". This makes no sense. I wasn't trying to get a gun permit, just ice.
Posted on Jan 13, 2009
0 characters
1 Points
Remove the ice bin. Remove two screws, holding the ice maker and unplug the power cord. Remove the ice maker.
On the new ice maker install the water chute (plugs in) and install the new ice maker.
Mar 13, 2012 | Refrigerators
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Ice Maker Not Working
Probably need a new ice maker,
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator ice maker stopped working
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
first off relax and give it time the ice maker need to cool to a certain temp before making any ice, 24 hours is a reccomnded minimum
Jan 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker
Pressure difference between the two water supply systems is the cause of the overfill condition. You may have to install a water pressure regulator in line to the ice maker water supply. Or you can try to control the flow by throttling the supply valve to the refrigerator.
Jun 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Please help
Are you installing a ice maker kit? If the ice maker is already installed all you have to do is connect it to the potable water supply in the back of the refrigerator and lower the bail arm to put it into operation.
Jul 15, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
927 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
