Question about Valcom V-1020C Main / Stereo Speaker
Connecting speakers to receiver
I was given a couple of pairs of valcom v-1020c speakers.  Can they be connected to a regular receiver? And if so, HOW?
  • computer_cod May 11, 2010
    What are you going to be using the speakers for?
These speakers are designed for use in an overhead paging or similar sitiuation. They require -26v DC power in addition to an audio signal. You can connect your own amplifier if you disconnect and bypass the one on the speaker. These are really marginal speakers for music, so it might be wiser to get someone to trade them for some that sound better.
Posted on Feb 08, 2008
How do I pair my HMDX Jam Classic to my telme2 Bluetooth
I don't know if you can do that, but there is no point in doing it even if you could. You pair and connect EITHER the speaker OR the headset. to a Bluetooth-enabled AUDIO SOURCE such as a phone, tablet, iPad, iPod, etc. The speaker and the headset each act as AUDIO RECEIVERS for those audio sources. What is the point of pairing/connecting two audio receivers ?
Jan 04, 2015 | Cell Phones
Bluetooth will not activate, tx-nr636 setting says its on but no light and device will not connect
To connect a Bluetooth-enabled device (phone, tablet, iPad, iPod, computer), follow the steps below:
1. Press and hold the button to put the receiver in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the receiver.
2. Turn on Bluetooth on the device you want to connect with the receiver and tap on Scan. The device will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the receiver's name, tap on the name to pair with the device. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the receiver will turn to a steady blue and you will see 'Connect' on the device. The two are now paired.Tap on Connect and then you will see Connected on the device. Your device and the receiver are now connected.
The steps above should be detailed in the set up guide that came with the receiver. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the device to the receiver, a "get to know you" process. After that, you just need to connect the two.
I am assuming that you have already hooked up speakers to the receiver. Start playing music from your device and enjoy listening to it through the receiver's speakers !
Dec 28, 2014 | Onkyo TX-NR636 Receiver 7.2 Channels, 95...
Connecting external speakers
If the speakers are wireless, wouln't the receiver connect to the speakers and some kind of transmitter connect to the TV?
Jan 20, 2013 | Samsung Hl-s5686w 56-inch Dlp Hdtv
How to connect bullhorn speakers to phone in workshop
What's going to power the bullgorn? We use 14 and 16 straded for speaker wire from an amplifier, or 24 guage with 24 volts DC feed to a Valcom amplified speaker.
In both cases, there's interface electronics. http://www.vikingelectronics.com/products/pdf/pa-2a.pdf
Carl
Jun 27, 2012 | Lands Phones
My dell 1209S projector is connected to a valcom speaker, but I can't control the volume
If there is a fixed volume input on the speaker, plug it into there. If not you can use your dell projector to adjust the volume.
Nov 20, 2009 | Valcom Audio Players & Recorders
Connecting 6 pair of speakers (12 total) via one stereo receiver
His receiver has enough power all 6 pairs of speakers, however, he should use a speaker selector switch. Niles is very well built and you can find them with an "on/off" button for each pair, and they have models that will independantly conrol volume as well. (SSVC-6) For a good unit, expect to pay from $250-$400. They will keep the unit at an 8ohm load and not over tax the receivers power supply.
Hope this helps
Jul 29, 2009 | Audio Players & Recorders
I need to set up 4 pair of speakers, two zones. all ceiling mounted.
Okay! all ceiling mounted speakers. I don't know about 4 pair of speakers.Here is the load down:
First pair of ceiling speakers would be left and right front from speaker A or Main output behind your receiver.
Second ONE,but a pair would be connect to the center channel output as your center speaker.
Another pair would be connect to the surround sound left and right(NOT surround BACK left/right.)
Now,you have 5 channel setup at this point,you still need to purchase a power subwoofer to the SUB PRE-OUTPUT behind your Denon receiver.
For Zone two,you would need to connect your other pair of speakers to surround BACK left and right output.
Go to your Denon MENU button,depending on which model you have,some of them will have an on-screen display feature(you would need to have a composite video cable connect from the video output behind your receiver to the TV video input in order to use the on screen menu.)If not,you would have to it view on the front panel of the A/V receiver.
You need to read the detail on how to setup the video and audio as well as distance and DB for the receiver through the menu button.
I will be frank with you,if you are an amateur,Denon is NOT easy to be setup on the first time.
solutiondoct
Nov 06, 2008 | Denon Audio Players & Recorders
Connect speaker selector to reciever
Dear fellow stereo fans:
First, you connect the wires which would go to your speakers in th respective speaker a or speaker b out. Second, connect one pair of wires from the receiver to the speaker selector. I hope this is helpful.
Nov 18, 2007 | Harman Kardon AVR 235 Receiver
Valcom V-1020C Main / Stereo Speaker Logo
461 people viewed this question
Top Valcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Valcom Audio Player and Recorder Expert? Answer questions, earn points and help others
