Apple iPod nano 3rd Generation Logo
Anonymous Posted on Aug 26, 2009
IPod Hold Is it a bad thing to put your iPod on hold when you aren't using it so that it won't come on? For example I put it on hold then put it in my purse when I go to school to keep it from going off. Is that bad? Or is there another way to keep it from coning on without using the hold button?
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Aug 26, 2009
Anonymous
Expert
Level 2:
Answers
60
Questions
0
Helped
21357
Points
219
IPod hold feature is just like standby for a cell phone, pda or computer. It will not hurt it and will actually conserve battery life.
Testimonial: "Thanks I was just afraid the button would wear out and get stuck or something."
My ipod won t charge
It could be 1 of 2 things. The first 1 I have had the experience of accidentally leavng my iPod plugged in charging for over a day. What happened...it killed the ability of the iPod to hold a charge & yes I tried with another battery & it was a no go. The second issue could be that your actual power supply cable has gone bad and won't work anymore. Now you didn't specify on which manner you're trying to charge it so if I didn't address your issue my apologies. There is a 3rd thing and no its not a combination of the 1st 2 I mentioned happening in conjuction...The 3rd thing could be that the power outlet you're trying to use doesn't work anymore so try another outlet plug.
My ipod won't turn on i just have a white screen and tha in nts only when it`s pluged
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
2answers
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
Just an apple when startup not working
Here are some things to try:
Press and hold the top and the home button down until the iPod Touch turns-off then release the buttons. Now press and hold the top and home buttons again briefly to start the iPod Touch. This is supposed to do a reset on the iPod Touch.
Next thing to try is to put the iPod Touch into recovery mode and restore the iPod Touch to factory defaults.
This is covered very nicely in this eHow.com article:
http://www.ehow.com/how_5508348_force-ipod-touch-recovery-mode.html
If neither of these suggestions work, then I'm afraid that it's time to take the iPod Touch in for service.
Thanks for using FixYa and Happy New Year.
1986 honda civic si over heating what could be the problem
Theres only 3 things that it could be.1.radiator cloged or won`t hold water,2.waterpump is bad,or 3.The thermostate is frozen closed.Thats saying that you`r belts aren`t slipping and that you`r water hoses are in good shape.
What should i do to turn hold off after opening up ipod nano 1gen
HI,
The "hold" switch is located at the top of the iPod nano.
TO TURN THE HOLD ON:
Slide the hold switch to the on position when you put the iPod away. This won’t accidentally wake from sleep when a button is pushed and drain its power.
TO TURN THE HOLD Off:
To start using your iPod again, just slide the hold switch into the other position and click a button to start it up again.
This will fix the issue,
Thank you,
2answers
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
1helpful
Yes
To reset iPod mini:
1 Connect iPod mini to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Menu and Select buttons for at least 6 seconds, until the
Apple logo appears.
If Your iPod mini Won’t Turn On or Respond
• Make sure the Hold switch is off.
Sansa 250
okey this sounds ... wierd... you uppgraded it? did it get bad tracks when you putted the tracks in or did it take a time..
your songs maby aren´t in rigth .... are you using mp3\wma songs look so they aren´t any other... well if it don´t helps you you can do 2 things leave it back to store and get help there or try rockbox www.rockbox.org
remember to read alot before installing it
i give you a fast guide about the diffren´t modes you canm boot to :
1.normal only start it while dont push any button
2.recovery mode hold(activated) and push rec button when boot screen comes ( this can be used for reinstalling or uppgrade a mp4)
3.manufrakting mode start mp4 while push centerbutton hold(activated)
4. i think it was one more but i forgot that one :p
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
