Question about Epson Stylus CX5800F All-In-One InkJet Printer
Epson CX5800F printer Netgear PS121 Print Server difficulties
Have the Epson CX5800F being served by the Netgear PS121 through a wireless server. Computer is running XP media center. It was working for a couple months after my initial install, but the computer was having issues from users messing with it, so I uninstalled both the netgear and epson software and started again. Now, when I install the printer, it prints just fine, though the status monitor can't talk to the printer. Upon reboot, the printer is offline according to windows and cannot print. "Disabling" the status monitor via the menu settings does not allow printing again, immediately or after reboot. Can still command line ping the print server though. I've found no way to install only driver without the status monitor (which I suspect is causing the problems), nor have I figured out how to uninstall the status monitor on its own. Deleted the executables it installs in windows/system32/spool, which seemed to prevent the system monitor from loading, but I still couldn't print.
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
Posted on Dec 17, 2007
Testimonial: "Sorry it took so long to post feedback. Your suggestions were very helpful, but we ended up replacing the equipment eventually out of frustration."
Tip
Configure PS121 with MAC OS X
Configure NETGEAR PS121 print server with MAC OS 10.4.X and may work for other version of MAC OS X
Please sure that the printer is working in direct connection with the computer.
1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
Open the System Preferences
Click on “Print and Fax” icon
Click on the “+” icon to add a new printer
Click on the “IP Printer” icon
Select “Line Printer Daemon – LPD”
1. In the Address field, enter the IP address of the PS121
2. In the Queue field, enter L1
3. In the Name field, enter L1
4. Select the printer manufacturer from the pull down
5. Select the printer model from the scroll box
6. Click Add
a. Click once on L1 to select it
b. Click on Printer Setup
Click on the “Installable Options” pulldown menu and select “Name & Location”
1. Change Printer Name to IP address of PS121
2. Change Location to: IP_.ip of PS121
3. Click on Apply Changes
The Macintosh is now ready to print.
on Mar 18, 2010 | NetGear PS121 Print Server
Can a Netgear USB Mini Printserver - PS121NA be used to share a USB Hard Drive over a LAN?
I apologize but you can not use this print server to share USB drives. This print server can only allow you to share printers.
I believe this answers your query.
Feb 03, 2010 | NetGear PS121 USB Mini Print Server:...
My Netgear PS121 print server requires disabled firewall (Win XP) to install. After installation, which ports has to be open in Windows Firewall, if I want the printserver to work with Windows XP Firewall...
You may try to set Exceptions on the XP Firewall configuration.
Open Windows Firewall, go to Exceptions tab.
Make sure that File and Printer Sharing is checked.
Then click Add Port.
For Port Number, enter 139 and select TCP.
Do the same for port 445 TCP, 137 UDP, 138 UDP, and 9200 TCP.
Nov 03, 2009 | NetGear PS121 Print Server
Netgear ps121 won't print
Possible reason why you cannot print with the print server is because the computer is not getting a valid IP from the router or a firewall is installed in the computer. You have to disable all firewalls installed in the computer.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
May 01, 2009 | NetGear PS121 Print Server
Netgear wireless ps121 won't connect to cannon MFP 4100
Try to disable Zone Alarm temporarily and print.
Also, can you login in to your wireless router and see if print server is on the IP list?
Apr 03, 2009 | Computers & Internet
Current installation guide and software download
www.netgear.com will have that information
Oct 14, 2008 | NetGear PS121 Print Server
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
2. Model of printer
Apr 26, 2008 | NetGear PS121 Print Server
Signifcant delay when printing
Your post does not mention all IP addresses in use, and which devices use wireless. That information would be helpful.
Is it possible that you are getting an IP address from a router for your internet access, then when you try to talk to your print server it may be trying to assign an ip address too.
(Sometimes a wired computer also has wireless enabled, which can cause an issue when one ip address has already been received on the wired connection and a wireless connection is also trying to connect.)
Mar 29, 2008 | NetGear PS121 Print Server
Epson Stylus CX5800F All-In-One InkJet Printer Logo
274 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
