Question about Adobe Photoshop 7.0 (321115627)
Photoshop 7 Croping
Photoshop 7, trying to crop an image 10 x 8 what or the step to take. And print it as a 10 x 8. I need help.
Thanks
  • Anonymous Dec 28, 2007
    I want crop an image in 5'' by 7'' ... how to do it..?
    Problem Solver:
Another possibility is that the picture is the right proportion, but the size is too big or small. To check this look at height and width in Image/Image size. If the picture is too big, just shrink it to the proper size by entering 7 and 10 inches. Make sure constrain proportions are resample image are checked. Also, resolution should preferably be 300 pixels/inch or more for a top quality photo. You can also use this method to enlarge your picture, but the resolution may suffer.
Posted on Feb 26, 2008
    Problem Solver:
  • 11 Answers
I use photoshop 10 but i believe there is not much difference in cropping. What you do is select your crop tool, with it selected enter your dimensions in the W and H text boxes at the top. In the box you would type in the corresponding box; "5in" or "7in" without the quotes. When you have entered your dimensions your crop tool will draw a shaded box as you drag it on the workspace that will be presized to your entered dimensions.
Hope this helps
Posted on Jan 14, 2008
PS CS6 How to drag a layer into another PSD file at-size?
>Open "My Computer" from your desktop. Double-click your hard drive.
>Open "Documents and Settings."
>Open the folder labeled with your user name.
>Open "Local Settings" followed by "Temp."
>Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
>Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
>Select "Save As" from the "File" menu when you find the temp file you want. This will make the file permanent.
also use Photoshop Restore Toolbox
http://www.photoshop.restoretools.com/
Apr 25, 2015 | Adobe Photoshop 7.0 for PC
Hi, how do I get my photos to be 300dpi? I have a panasonic DMC F27. Do I do it in photoshop? Sorry, I know very little about cameras. Thanks
1. Select Crop tool
2. Select Resolution
3. Type in 300
4. Crop whole picture as desired
5. Click done
6. Then Save file as jpeg
7. Make sure max quality is on
8. Then click okay
May 03, 2011 | Cameras
I needed to crop in my photo
There should be a crop button at the top, where the tools are, just hover over them till you see Crop. Click it, it will then ask you to select an area that you want, basically, it gets rid of the rest of the photo not selected by you. Hope this helps.
Here is a link to "How to Use Adobe Photoshop CS3"
http://www.photoshopsupport.com/tutorials/cs3-photoshop-10.html
May 15, 2010 | Adobe Photoshop® CS3 Extended Full Version...
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
HOW TO RESIZE PICTURE AT ADOBE??
To resize an image with Adobe Photoshop Elements 4.0 you first need to open the image. After opening the image you will select Image---> Resize---> Image Size. If you select canvas size the image itself will not change.
At the Image Size menu, make sure that the "resample" check box at the bottom of the menu is selected. Then enter the desired resolution and width/height. For printing an image, a resolution of 300 pixels/inch or more is desirable. When images are intended for computer or web display, 72 pixels/inch (sometimes referred to as dpi) is sufficient. You can set the image size in pixels (at the top of the menu) or in inches (at the lower part of the menu). Once the desired sizes are entered you only need to press "ok" for the change to be made.
Photoshop Elements also offers another method of resizing an image. You can use the "crop" function to resize your image quickly. The crop tool looks like a small square with overlapping edges and can also be accessed through the Image menu bar at the top of your screen.
Once the crop tool options bar opens, select "custom" and then enter the desired height/width and resolution. To crop to specific pixels you must enter the letters "px" after the size number in the width/height boxes. If only one dimension is important you can enter information in only one box and let the other dimension be determined purely by where you place the crop line.
After entering your preferences you will click and drag the crop tool across the image to select the part of the image you wish to keep.
Jul 17, 2009 | Adobe Photoshop 7.0 for PC
I need to know how to get a 2 seperate pictures in one picture
hello,
try it in photoshop again,
1) Open the picture in Photoshop, Click on the LASSO tool or press "L",84c084e.jpg
2) Select the picture by clicking node by node, every edges of your picture, join the starting point and the endgin point to make the selection,
it will look like this,
3) Now copy the selection (ctrl+C)
4) Then press Ctrl+N to make new canvas, make the dimensions of the canas accordingly
5) Now paste the selection into new canvas by pressing Ctrl+V,
6) Crop another picture using above steps and paste it into the new canvas,
7) now the final step is Open any cool background image which you wan to put in the background of your pictures, Open it in photoshop, press Ctrl+A(select all command) and paste in the new canvas, make sure to drag the background layer in bottom of all layers, and transform if you want to change its size using ctrl+T,
Tadah!!!!
I have made it in hurry, so sorry for the rough edges in picture :)
Enjoy!
Apr 27, 2009 | Adobe Photoshop Elements 6: Windows
Command Action
Open - Window - Action. Click on arrow on top right. Create New Action name it, and record an action by cropping one of the images.
Go to File - Automate - Batch. And choose folder with images you want to crop.
Apr 05, 2009 | Adobe Photoshop 7.0 for PC
Cropping Photos
sure..check your scaling settings in photoshop, which is based on the size of the paper you're using.
Feb 12, 2008 | Olympus P 400 Thermal Printer
Canon A530
The only way I know to help you is to suggest a software approach.  The reason I asked for your OS is to know whether or not a Mac solution (which I can personally vouch for) or a Windows solution (which I don't know for sure, but believe will work.
What you need to do is to change the images to that 1.5:1 ratio by adding blank white (or black, or whatever you want) to the long dimension.  This can be done easily using the batch capabilities of a program like GraphicConverter (Mac), Irfanview (PC) or Photoshop or Photoshop Elements (both).
If you are like me, then you want to save the expanded images to a new location with a new name.
If you tell me what software you have, I can give you step by step instructions for GraphicConverter or Photoshop.
A second alternative would of course be to find a place that can make prints in the same ratio as your images.  The problem is that this somewhat unpopular print ratio.  Oddly, it is a very popular image ratio for inexpensive cameras.
A third alternative approach would be to just take the potential cropping into account when you take the picture in the first place.  You could even place some tape over the parts of the LCD that will get cut off.
Please let me know if I can be of any more help.
Feb 07, 2008 | Canon PowerShot A530 Digital Camera
Process Cropping
Most digital cameras have an aspect ratio of 4x3. 35mm cameras have an aspect ratio of 3x2. 6x4 photopaper also has an aspect ratio of 3x2. Therefore you don't get cropping when printing from 35mm film. To make the picture fill out the 6 inches, the digital footprint has to be 6" by 4.5". So .5 inches is removed in the process. If you can find a processor that will print 5.333 x 4 on the 6 x 4 paper, there would be no clipping necessary. Since you have Photoshop, you can crop the photo to a 3 x 2 ratio. That way you control what is cut. I use Photoshop Elements and when I use the Rectangular Marquee Tool, I set Style to "Fixed Aspect Ratio" and Width to 3, and Height to 2.
Sep 14, 2005 | Creative Labs PC-Cam 300 Digital Camera
Adobe Photoshop 7.0 (321115627) Logo
140 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
