Memory Error Messages
HP Compaq 6910P - memory error messages "pop up" when using various applications, including MS Excel.
Is this related to hardware, OS or software problem
  • Kyle15 Dec 05, 2007
    No. It is a brand new laptop. It was built by the IT division and before the profile could be setup, the errors started. The supplier says it not a hardware fault. We have unistalled and reloaded the OS twice now and we still the get the errors. So there is a debate on who should take responsiblity.
    If it is hardware failure then the laptop must be returned. If it is application related, then the IT division must try to find out why it is happening.
    But nobody wants to take responsiblity and do the proper analysis.
    Problem Solver:
  • 14 Answers
It could be either one of them. It is hard to tell without actually having the computer here. This may sound crazy but make sure your hard drive is not full. Windows uses a swap file that grows each time your computer is powered up and then deleted when powered down. If your hard drive is getting full it has been known to generate memory errors especially when using memory intense programs such as excel and programs like photoshop. Do a system cleanup and defrag your hard drive. Hope these suggestions work!
Posted on Dec 05, 2007
System we have here at work has BSOD 2x with xeskmdrv.dll error 50 blue screen - lookin for reason/solution on this
As you probably know, this is a Xerox printer module. Below is more info on Stop 50 but in general, you might try reinstalling the printer with the latest drivers.
Stop 0x00000050 or PAGE_FAULT_IN_NONPAGED_AREA
The Stop 0x50 message indicates that requested data was not in memory. The system generates an exception error when using a reference to an invalid system memory address. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause Stop 0x50 messages.
Possible Resolutions:
• If you added new hardware recently, remove and replace the hardware to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the hardware manufacturer to determine if the component has failed.
• Stop 0x50 messages can also occur after installing faulty drivers or system services. If the file name is listed, you need to disable, remove, or roll back that driver. If not, disable the recently installed service or application to determine if this resolves the error. If this does not resolve the problem, contact the hardware manufacturer for updates. Using updated drivers and software is especially important for network interface cards, video adapters, backup programs, multimedia applications, antivirus scanners, and CD mastering tools. If an updated driver is not available, attempt to use a driver from a similar device in the same family. For example, if printing to a Model 1100C printer causes Stop 0x50 errors, using a printer driver meant for a Model 1100A or Model 1000 might temporarily resolve the problem.
Sep 16, 2010 | Computers & Internet
HP Compaq 6910p - how do I get the Memory Stick Duo Adaptor to be read by my laptop? I inserted the memorystick pro from my Sony camera into the associated adaptor, but the laptop isn't seeing it. Thanks.
into a adapter that is not built into the pc? or the one on the pc? if it is on on the pc does it say it supports MS DUO or just marked SD MMC?
If its external test it on another PC, if it works switch the usb you are using, on your PC
Aug 16, 2010 | HP Compaq 6910p Notebook PC PC Notebook
Svchost.exe applicationerror The instruction at "0x012cf496" referenced memory "0x0123f496". The memory could not ne "written".
This is the most common question when computer users start to experience this error messages pop up on their screens. Many people immediately call in their computer-technicians to fix this problem and end up paying huge amount of money on professional fees.
Unknowingly, this problem could be easily fixed on your own, even if you know little about computers; and further prevents this problem to occur in the future. There are many ways to solve this and I shall discuss further on these methods; as well as the ones easier for you to do.
One of the best methods in dealing with this kind of situation is to verify the settings of windows update. If you keep on updating your system, some of the applications may not be compatible with your OS; hence, this error message shows up. In some cases, you may need to register again your update DLL file in order to fix this issues.
Another method is to reboot your computer in order to reload your operating system. There are times when your computer encounters problem during startup and rebooting your system can resolve the issue. Still another technique is to remove update files which are already corrupted; these files are usually found on your registry. In using these methods, you may need some expertise in order to make precise identification of corrupted files.
The best way to solve your problem is to use registry cleaners. This software can fix this trouble because this problem may be related to registry issues caused by the build-up of unwanted trash files. These junk files can cause various types of problems in your computer including svchost.exe application errors; it can further cause your system to run slow, takes longer time to start up, and eventually crash if not resolved immediately.
Therefore, the next time you encounter this message, you don't have to call in your technician to fix the problem for you; because you already know how to fix svchost.exe application error yourself using registry cleaner software.
http://www.ultimatepcutilities.url-go.com
Dec 01, 2009 | Microsoft Windows XP Professional for PC
There was a powercut whilst I was at lunch and my laptop was connected via the mains only. When I restarted Excel 2007 complained of memory problems and failed to complete loading. It was fine this...
Are you opening a an excel file and excel crashes or are you opening up excel by itself and it crashes?
If your opening a file then it's most likely corrupted. If it's just excel that is crashing then you might have some files that got damaged during the power outtage. To fix that problem close all your applications, go to my computer, right click on C drive, properties, tool, error checking, check now, click both options and click ok. It might ask you to reboot. If excel doesnt' work after that you will have to reload MS office. Your file system will be fixed though.
Aug 06, 2009 | HP Compaq 6735s Notebook
Text message failure, error message
reset that phone
keys; 3845#*610#
try this
May 11, 2009 | LG KT610 SYMBIAN SMARTPHONE
Error messages on Vista Home Premium
uninstall the old Zone Alarm and install the latest version.
Mar 18, 2009 | HP Pavilion dv2000t Notebook
Speed of excel is v slow
you are using microsoft office 2007 version. it need 1.5 GB ram. how much ram in your system?
Jan 26, 2009 | Compaq Presario 5000 PC Desktop
"Not enough memory to run microsoft excel."
it is conflicy with win xp updates.
check your ram.
go to device amanger then advanceced increase your virual memory to 1.5 *your rammmeory.
Jan 03, 2009 | Microsoft Excel for PC
MS Excel
Can you please provide any additional information, including error messages generated by Excel? Without knowing the specific error message, your surest solution is to completely uninstall Microsoft Office by going to your Control Panel and double-clicking "Add/Remove Programs". Then, once Microsoft Office is uninstalled, reinstall it using the CD.
Nov 12, 2007 | Computers & Internet
Insufficient memory
If it's host based, that means when you print:
1) from word, your word document is converted to a series of characters, and sent to the printer.
2) from excel, same thing.
3) from works, it's converted to a bitmap, instead of characters, which can take up significantly more space on your drive.
My guess is that if you imported a photo into word, then tried to print it, you might face similar issues.
If so, it's time to free up some space on your hard drive, or purchase a second one, or add some physical memory to your PC.
Oct 12, 2007 | HP LaserJet 3600n Printer
Computers & Internet Logo
107 people viewed this question
Alun Cox
David Payne
David Payne
