Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Sve47500w jenn air oven
Bake element caught fire replaced element now element wont heat checked oven sensor ohm out at 1099 ohm should be ok? oven temp will climb to 190 degrees i think boil elment trying to come on
  • 7 Answers
SOURCE: I HAVE A JENN-AIR SVE 47100 IT STARTED TO PRE-HEAT
Probably relay control. I have similar problem.
Best estimate I have had is $300, relay control circuit board, Part #12001689 costs $225.
I am getting a NON Jenn Air. Repair record not so good.
Check Consumer Reports
Posted on Mar 15, 2009
  • 10865 Answers
SOURCE: My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
Posted on May 31, 2009
fixyourboard
  • 310 Answers
SOURCE: My oven will not heat above 190 degrees. It just
Sound like the bake element has gone bad.
Posted on Oct 06, 2009
t955i
  • 30 Answers
SOURCE: Jenn-Air SVE47100 Oven Won't Heat
are you still getting power to the oven? breaker ok? there may also be a fusible link somewhere on the circuit
Posted on Nov 21, 2009
SOURCE: Jenn Air Range SVD48600P Oven heating elements not
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43495&diagram_id=661873#d661873
Above is your parts diagram.
If the element melted then a considerable amount of current must have flowed through all attached Componentry. Including the Element switches which are most likely burnt out too, the contacts evaporate.
You also have Thermistor sensors these too most likely will be Open Circuit, you need to check with a meter, they should be SHORT CIRCUIT.
The sensors cannot be "Reset" they must be replaced.
You simply need to trace out where the wires go BACK to the controller, and see if you have voltage at this point, work back testing as you go, until you find the mains voltage again, the replace any components that are NOT passing the current through.
The circuit is pretty simple, from the mains IN switch, to the Element Control from the element control through the Relay, and onto to the element itself. The relay can also be "Turned Off" via the "Control circuitry" too.
Posted on Nov 12, 2010
Bake Element
I would start by checking the temp sensor of the bake temp settings. Pull it and its most likely bad your thermostat control, also did you ohm out the element before installing it i have bought many new bad ones as well. anything else just ask.
Apr 05, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Grease fire in oven. elements would not come back
First verify 220 volts to the range where the cord connects.
Second,unplug the range and remove the element again and using a volt/ohm meter set for ohms or continuity check the element. No reading is a bad element.
Third, if power is OK and the element reads continuity check for power in at the oven control in the control panel.
Set for Bake and check power Out of the oven control.
No power out is a bad element.
If the control is OK,remove the oven temperature sensor and with the meter check for 1100 ohms +or- 25 ohms.
If not correct,replace the temp sensor.
Mar 18, 2010 | Roper FES330 Electric Kitchen Range
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven heats very slowly (Jenn-Air JGS9900BDS). Cooktop works fine. Broiler works. No error codes.
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Jul 08, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Bake oven element blew
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
141 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
