Question about LG 32LC2D Television
Hdmi connection I have tried to connect my PS3 through the HDMI but when I turn to the HDMI channel it comes up that is connecting for a few seconds then it says no signal can you help or give suggestions please.
  • Anonymous Nov 25, 2008
    hdmi connection does not work on my LG 42".
    please help!
You have to contact customer service on 08708735454 as it needs to be upgraded - pretty poor from LG !!
Andrew
Posted on Mar 15, 2008
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Play anything ps3
Hold on. Have you plugged in the PS3 with HDMI before?
try plugging in with an AV cable, the one that came with the PS3. You would then locate in the settings to change modes see the video for help.
May 02, 2014 | HP Pavilion Computers & Internet
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Televison & Video Logo
183 people viewed this question
