Cloudy patches from backlight leakage in LCD TV
Is it true that almost all LCD televisions suffer from backlight bleeding? This is what I have been told by the local Philips distributor here in Malta. This backlight leakage is very annoying especially during dark film scenes, it appears as cloudy patches across the screen. I dont know why no reviews ever mention this issue. I have a feeling that consumers get the worst quality products while those sent for reviews are carefully selected. I had my TV replaced with another one that suffers from the problem only worse than the first. I am now afraid to change it again. The cloudy patches' pattern seem to change and sometimes, but not always, it becomes hardly noticeable after some time (usually an hour) from switching on.
http://www.angelfire.com/ultra/markgrech2002/philips_lcd_tv/
I have found that lowering the brightness level does not seem to affect the backlight leakage problem. However, I have found that increasing the brightness makes the bleeding less obvious as blacks become more gray and mixes with the cloudy patches. In this way the contrast between the two is less and hence the problem is less visible. However, this reduces picture quality significantly as blacks are less black and the colours are sometimes washed out and I will need to change settings again.
  • 3 more comments
  • Anonymous Dec 06, 2007
    I have Mitsubishi Diamond and cloudy patches on light screen (instead of the usual cloud on black screen) Tech support tells me they have never heard of such a problem. What can I do?
  • twinsane1 May 18, 2008
    i have 2 vizio 32" lcd television sets, both are suffering from this problem. Any cure?
  • Anonymous Jul 27, 2008
    lcd hdtv samsung. colors of green and purple shadows
  • ksk123 Feb 18, 2009
    I also have the same issue with my new Samsung LCD TV LN52A860 (Latest Samsung TV), The patches are ugly and just received the TV yesterday. Bought it from 6Ave and didn't talk to them yet. Please be careful before buying LCD TV..
  • smyffy17 Mar 16, 2009
    Same thing one large cloudy patch that seems more noticeable during darkier pictures. I have been searching for a cur ebut have found nothing.
You have to send it back to company to fix this problem>
Posted on Mar 10, 2009
Visio E701I-A3 TV backlight part number
The following picture symptoms indicate a bad LCD panel, and NOT a bad back light or board:
-One side of the picture is darker than the other
-Picture has horizontal line(s)
-A dark, cloudy spot spreads across the picture
Jan 22, 2016 | Televison & Video
LED TV back-light bleeding, spreading white cloudy patches on corner edges.
Check the backlight inverter board, and backlight LED array. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 13, 2014 | Sansui 42" Widescreen 120Hz 1080p LED HDTV
Sony klv 32s530a lcd tv program sound ok no pitcure but backlight ok
unplug everything and test one input device at a time (ie, game console, computer, tv, cable, etc) and select the appropriate input for whatever you plug in.
could be the device being plugged in and not the tv at all.
Also, do you get a menu when you press the menu button on the side of the television? If so, true, backlight could be okay.
If all this fails, turn off and unplug tv, remove rear panel, and, one at a time, unplug and plug in every connector jack (cables) that you can find on the back of the unit. check for loose jacks/connectors, smell see if anything smells burnt.
Lastly, try not to electrocute yourself when inside the tv.
Feb 20, 2013 | Sony KLV32S400A 32 in. LCD TV
My samsung tv replace the power supply board. got sound no pictuer replace the backlight inverter stell no picture
You have to check whether the back-light inverter gets its proper voltages to function. There as many voltages that controls the back-light inverter. Check these is a skilled work. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 23, 2013 | Samsung LN40A650A LCD TV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Picture shuts off
Is there a dark patch when you see the picture, easiest way to check is on the tv tuner with no cable attached, this way you have a grey static screen, if there is a darkness across the screen when it lights for that breif moment, then it may have a broken backlight tube. Had the same problem with my 32" LG.
Jul 29, 2010 | Astar LTV-32ASB 32 in. LCD Television
One day old samsung 40LC530 LCD tv shows a dark patched screen
that is a factory defect you call the dealer for the warranty.the defective part of your tv is the inverter board.this board supplies high voltage supply to the backlight cold cathode flourescent lamp.This lamp is the one illuminating the screen of the tv..the lamp is installed at the top and bottom of the screen thats why the center of the tv is dark because the lamp does not lit well..tnx
hope i help you
please rate my help..
Jun 05, 2010 | Televison & Video
I've noticed a dark patch in the lower right corner of the screen. Is this a bad panel or backlight? It's mostly visible in scenes containing blues.
Sounds like a backlight is out probably due to a bad inverter board. If you can see the spot when the tv is off its probably a bad lcd panel.
Mar 13, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Black parts of screen looks light light is shining on it
Your LCD TV uses backlights and they can be slightly visible when viewing a letterbox movie.  However, if the light is really bleeding into the black, there could be a problem, but mosty this is common.
Mar 24, 2009 | Samsung LN-T3253H 32 in. LCD Television
I bought a Samsung 46" LA46F81BD today pluged it in and tune the tv. The picture was great after about 30 minutes the TV went blank and lost picture. I still have audio. does anyone know what the...
If this is a projection TV,you may have suffered premature lamp failure.If it's an LCD,could also be a backlight lamp failure.Either way,it should be under warranty if it's new.
Mar 13, 2008 | Televison & Video
Televison & Video Logo
3,332 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
