Question about Xerox Phaser 7750DN Laser Printer
Paper jam 2 fuser
I r/r'd the fuser and exit transfer unit, but the paper jams everytime @ the fuser.
    Novelist:
  • 208 Answers
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
The error 010-311 appeared. i reseated the fuser unit several times. no success. any ideas?
Hi Anonymous,
If you have a spare Fuser Unit I would suspect you install that and try it.
Have you had a jam in the fuser in the past in which case check the paper sensors are working correctly by activating them with a sliver of paper.
I have known the exit sensor to be jammed and only when you remove the exit transfer unit to the finisher will it be obvious.
If that is a but daunting then you might need to call in Xerox.
Good Luck.
Jun 15, 2015 | Xerox WorkCentre 7120/P Color Advanced...
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
Sir ,ir 2020 paper jam at fusing unit.some times half of paper will come out,sometimes jams at the entrance of fusing unit.i changed every sensors,then changed new fusing unit,then feeding assembly...
Sometimes you can vlear a fuser jam with a manilla folder. Open the copier let it coll a bit and slide a manilla folder through the fusing unit. If it is just pieces of stuck paper the folder can sometimes push them out of yhe wsy ad you gorce it through and pull it out the other side. The fuser has two rolls one heat and one pressure both of these rolls have small fingers which are supposed to kerp paper from sticking to them. Sometimes these fingers get bent or damaged and this causes the actual jam. There is also an exit sensor that detects jams in this area it can have a damaged part as well
Jan 20, 2018 | Canon iR 2020i Laser Printer
Paper jam signal
I know your copier has sensor
1. Paper feed sensor in cassette
2.Paper feed by pass tray sensor
3.Transfer unit sensor
4.exit sensor in fuser unit
5 Paper exit sensor duplex unit
may be any sensor displace or broken
its open
please check it and fix problem
Jul 14, 2012 | Canon imageRUNNER 210S Copier
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
MACHINE GOES OFF WHEN IT STARTS TO BOOT
Describe correctly whenever is the paper jam.If in the transfer section change the transfer/separator corona wire,and clean the sincron roller.If the paper is blocated in the exit parts,check the fuser unit parts and verify the exit actuator(located in the fuser unit).
Nov 05, 2009 | Minolta Office Equipment & Supplies
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Paper jam at fuser
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Dec 04, 2007 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
608 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
