Question about Sony Ericsson W850i Cellular Phone
K850i Hi - just received a new SE K850i. When I put it into camera mode, the screen is black. Not sure if the lens cover is opening all the way, but it is automatic so no way to check. No changing settings seems to help, e.g. brightness etc. Any ideas on this? Frustrating!!! Cheers.
  • 3 more comments
  • leemdylan Dec 06, 2007
    My volume button doesn't work. All it does is skip the tracks on the mp3 player and the sound is really quiet
  • Anonymous Dec 09, 2007
    Ive got the same problem my phones shutter for the camera just stopped opening only had it 1 week!!!
  • coldplay678 Dec 27, 2007
    my camera shutter will not open
  • MANIEKOK Jan 06, 2008
  • CALIalska Jan 11, 2008
    omg i have the same problem to! i asked on here if anyone knew how to fix it and one guy replied back it was prutty helpful i guess...
Does any1 know how to open up a k850i me speaker and earphone have stopped working
Posted on Sep 06, 2008
Wait for new firmware and claim that shit
Posted on Jan 10, 2008
Hay i have the same problem
Posted on Dec 27, 2007
  • 3 Answers
Just make sure your hands are not touching the side where the cam is... there is a sensor there that you might have been blocking while taking pics....
Posted on Dec 05, 2007
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
The screen on my camera stays black after the camera is turned on. The lens cover is open. If I take a picture it will just be black.
If you transfer the picture to your computer and you get a black image then your "lens" is faulty - actually a cmos based receiver.
If the photo is ok - then the back LCD screen is at fault.
Either way, it needs fixed and if under guarantee contact the manufacturer and ask for a replacement, or take it back to the store you got it from.
Or if out of warranty you will need to buy a new one I am afraid.
If you have some technical skills you could look on eBay for another broken one of the same model as yours and put the two together to get a working camera.
Jan 07, 2011 | Cameras
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Canon service centre. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
Aug 09, 2010 | Canon PowerShot S2 IS Digital Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
The cover lens of my k850i wont close
the camera trigger is damaged on the back of the main board needs to be replaced for software and hardware repairs contact kas at
Feb 17, 2009 | Sony Ericsson K850i Mobile Phone
The easiest way to take pics with the SE K810i, I just slide the lens cover and it auotmatically goes to camera mode
Jan 06, 2008 | Sony Ericsson W850i Cellular Phone
Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 31, 2007 | Sony Handycam CCD-TRV68 Camcorder
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Cover open, camera does not turn on.
Completely open lens cover by sliding the lens cover all the way to the right until you hear two clicks. The first click will put the camera into playback mode. The second click will put the camera into shooting mode.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Sony Ericsson W850i Cellular Phone Logo
426 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
