Sony CDX-757MX 10-Disc CD Changer Logo
Anonymous Posted on Aug 26, 2009
Cd changer needs to be constantly reset when I start car
Cd needs to be constantly reset when I start car
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
1253
Points
9
Wire the red and yellow wires together and tape(electrical) and turn the entire unit off by the off switch on your reciever (you will have to reset the unit for the final time- fader /bass/treble /balance/) what you have done is by passed the key switch( also look under the reciever for a "switched or unswitched button or toggle...
peace
3helpful
Need wiring diagram for sony xr-c8200.need to know what color wire is the power wire.
red is switched or ignition power, yellow is constant power, black is ground.
1helpful
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
1helpful
I need to reset my cd changer how can i do that??
if there is not reset switch (will usually be a small hole about the size of a pencil tip) just disconnect power to the changer. this can be done by disconnecting the cable(s) to the changer.
Wiring Diagram for CDX-FM687
red is swiched ignition yellow is constant power and the sound is transmitted to the antenna. re small box with antenna in and out
1helpful
I have the same problem error 4 in my lexus rx330 please help me
I just left the Lexus dealership w/ my ES 330 (my changer reads "Error 3" upon starting my car, it also makes a loud ticking noise); go figure, the mechanic/technician there informed me that I need another motor for my disk changer - Merry Christmas and hello $675!
After turning your car off for about an hour or so, the cd player is supposed to reset itself enabling you to retrieve your cd's. Attribute this to having utilized burned cd's.
Hi i have a older cdx-65 cd changer
IT WILL NEED A SERVICE, POSSIBLE THAT ONE OF THE SWITCHES IS FAULTY
oops caps lock was on sorry :)
Mark
www.blueice-electronics.co.uk
Reset code needed
Put a pen inside the small hole under the CD holder to reset the machine (when turned off).
Cd changer quit
try unpluging the cd and then pluging it back in, thgis shopuld act as a reset.
Mark
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
