Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Echo and fast light on together
The dishwasher seems jammed how do you get to the motor and check the blades to see whether they are stuck
  • 868 Answers
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
The motor makes a weird whirring loud noise but the gears seem to be turning still the arms are still turning and the water is going in fine it seems to be any time the dishwasher is on and in any cycle....
So it turns out that it was the disposer blades right behind the motor that were causing the problem. I took the filter off of the drain and found I had a piece of glass and a plastic army man gun trapped in the filter to the drain that the blades were hitting and stuck on. I took them out made sure the blades spun freely and then replaced the filter. It works as good as new!
Feb 15, 2010 | GE GSC3400G Built-in Dishwasher
The pump motor seems to be jammed on my GE Model GSD2000j I was gone for a few months and it stuck on the 1st wash when I returned. The motor will not turn freely and is buzzing and heating up . Can I free...
Dishwasher motors are susceptible to getting stuck if not used regularly. Manually spin the motor to free it up. Dishwasher motors are not serviceable and must be replaced if found defective.But try to access the bushings/bearings and put a few drops of lubricant then spin it manually to free it up.
Aug 31, 2009 | GE GSD2000J Dishwasher
Stuck on clean light always flashing
There is something jammed in either the arm or blade that is setting off the code.
Jul 01, 2009 | Whirlpool 24 in. Portable Dishwasher...
Whirlpool dishwasher spinny thing is rattling
Hi, I suggest u to check these :
  1. Check the spray arm for damage and obstructions
  2. Check the inlet filter screens
  3. Test the water inlet valve
  4. Check the motor and mounts
  5. Check the fan motor and blade
  6. Check the drain for obstructions
Apr 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher won't actually turn on this morning. When I push the start button, it hums, and the lights by the cycles flash, for about two minutes, but it won't actually run through a cycle.
Your motor is probably stuck.
Remove power from the D/W.
Remove the lower access panel. The motor will be in front of you.
Turn the blades in the end of the motor counterclockwise until the motor turns freely. You will need a flat screwdriver to reach in and turn the blades.
When it frees, repower and try it again.
Mar 14, 2009 | GE Adora GHDA654LBG Dishwasher
Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Jan 24, 2008 | Oster 6678 14 Speed Blender
Stuck motor?
bert, to get to the sump and chopper assy. First remove the lower spray arm by holding the top tab and turning the spray arm off. Next grab a hold of the rear feed and turn it to the right until it unsnaps from the rear feed assy. Now you remove the filter and accumulator assy. It has torq screws, remove and lift off. Now the chopper cover will be on the left, one torq screw and it will lift off exposing the chopper blade. This is probably where it's jammed. Look at the attached pics. It will help you. Catriver.
Jun 15, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
56 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
