Question about SanDisk Sansa m230 MP3 Player
Cyclic Redundancy Error
Hi, I bought a sandisk m230 just 1month ago. I just tried loading songs in it. When there is still half of the memory is free, the mp3 player started giving me an error "Cyclic redundancy check error.......". Now, even if I delete few songs, I'm unable to copy the new ones. Please help me to get rid of the problem
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Data error cyclic redundancy check
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
SanDisk Memory Cards & USB Flash Drives Data error cyclic redundancy check
Try this, go to start, all programs, accessories, now RT click on command prompt and pick run as Admin.
Now type chkdsk G:
G is what ever the card shows as, in your PC, so if your card shows as E: then use E.
When it's done you will see C:\windows\system 32
Wait it might take a while.
Now type DiskPart
wait, you will see a few lines one says microsoft and when it's ready you will see it say
DiskPart> rescan
So after DISKPART> type rescan
Now try and delete everything from the card and do a quick format.
If this didn't work, you'll have to shell out 7.00 for a new card.
Apr 14, 2013 | SanDisk Adapter An 8 Gb Micro Sd Hc Memory...
Cyclic redundancy error when copying backed up files into Itunes
Files with cyclic redundancy errors means these files are corrupted and cannot be copied. Since you cannot copy these files from your faulty hard disk again then these songs are lost and you need to download them again.
Nov 27, 2012 | Apple iTunes
HI! this is Alex Walker expert to fix this issue for you call +1(518)348-9393 Thank You
Jul 03, 2017 | NetGear WG111V2 Wireless Adapter
Problem is occured during installation of USB Mass Storage Device An error occured during the installation of the device Data error(cyclic redundancy check)
Try uninstalling the USB root hubs in the device manager and then restart. They will reinstall upon the restart.
It may also could be a bad power adapter.
Dec 06, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Error insaling softwere
try downloading a software from FILEHIPPO.COM, 9DOWN.COM, DOWNLOAD.COM then just use your sn. hope this helps
Jul 03, 2009 | Ulead Videostudio 8 for PC
I keep getting a "cyclic redundancy check error"
It could be a few things that's wrong.
Check that the lens on the CD drive is clean and also make sure that the install disk is clean and free of scratches and then try to reinstall the game again.
There could also be some bad sectors on the drive your trying to install too, to check this right click on the C drive and select "properties", then select "tools" tab, in the tools option check the volume for errors.
Good luck
Jun 19, 2009 | E-Machines eMachines Desktop PC
Data error cyclic redundancy check. I have windows XP.How do I fix this?
Your disc is scratched. That error will come up when it happens. Try to clean your disc. get all the fingerprints off of it.
May 24, 2009 | E-Machines eMachines Desktop PC
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
SanDisk Sansa m230 MP3 Player Logo
255 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
