Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Brush belt The brush belt is loose and the lever control does not do anything.
I noticed the same thing myself. I had set the handle in the upright position, and laid the cleaner on the table to remove the rolloer brush. When I re-installed it I noticed the belt was really loose.
I checked several things before I finally lowered the handle to the operating position. This tightened the belt up, which makes sense when you stop and think about it. If you sit the handle upright to use an attachment you don't want the roller brush working away at your carpet when you don't need it.
Placing the handle upright disengages the roller brush by loosening the drive belt.
Posted on Dec 04, 2007
The brushes on my bissell quick steamer don't turn or anything
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 24, 2016 | Bissell Vacuums
How do i replace the belt on my hover
lower handle to floor and flip entire unit over. In the bottom near the brush, there are 2 levers that hold the cover on. flip both levers and pull up on cover. It will come out of the 2 wire holders that hold down the 2 front tabs.With the cover removed you can easily access the brush. Firmly grasp 1 side of the brush and pull straight up. This may take a lot of force as the brush may have been seated for a long time. Pull both sides out and clean the area underneath the brush. Also make sure nothing is wrapped around the brush or motor.
After cleaning you're ready to install new belt. Place new belt around brush. After pushing brush through the new belt, with belt loosely around brush slide brush back into housing 1 side at a time. The brush fits in very tightly. The ends have 2 pieces of metal that act as springs, these are installed facing the top. Make sure the brush is pushed down tightly toward the bottom or the cover will not fit right. Once brush is in stretch belt around motor tip. Replace cover by placing the 2 tips into the wire clips and close. Flip the latches closed and turn machine over. Lift handle and you're good to go. You have now completed the worlds longest instructions for a vacuum belt...ever!
Jun 11, 2012 | Vacuums
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
THE BRUSH DOES NOT WANT TO TURN AND THERE IS NO STRING OR ANYTHING WRONG WITH THE BRUSH, EXCEPT IT DONT WANT T0 TURN ONLY NOW AND THEN.
Will it spin if you turn it?
I'd guess that the belt is either loose, or it's worn out and is slipping instead of turning the brush.
Solution: buy a new belt and replace it.
Aug 25, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The V belt is too loose. The brush switch
Did you purchase the exact replacement belt for the vacuum, or did you buy one to match the one you have?
It sounds like you have the wrong belt, but, it could be the roller brush is not properly installed or the roller has worn down significantly.
Dec 18, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Twirly thing under the vacuum has stopped spinning
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Aug 18, 2009 | Dirt Devil Featherlite Bagless Vacuum...
The brush on my dyson ds14 will no move.
Can u turn the brush by hand with the vac off. Sounds like a bushing on the brush is siezed or mabe the belt is worn out and too loose. Try replacing the belt
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
Brush on/off lever
Replacing a belt or how to get into the vacuum cleaner . It is a Dirt devil Reaction D2
Oct 09, 2007 | Dirt Devil M1100009 Reaction Soft Touch...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
95 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
