Question about D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter
IE will not connect to internet
I have the D-link wireless card, it connects fine like it should, however my computer will not connect to the net. It show's connected on the task bar and it even is sending and received packets but IE will not pop up, it gives me the "this page cannot be displayed" it worked before but it just quit for some reason. HELP!!!
  • 2 more comments
  • newcom Dec 19, 2007
    got new computer put d-link in my new computer but it will not allow me to access on to the internet
  • snooku Jan 29, 2008
    I have the same problem. It was working fine then suddenly it started to develop problems. 1st it my computer would freeze after a while upon getting a connection (which required a hard boot). Now I can't get it to connect at all. And I see that a signal is received at any where between 70 to 100%. Occasionally my adapter light even flashes indicating something is happening.
  • YOTABOY Jan 29, 2008
    YEP, SAME PROBLEM - UPDATED DRIVERS, CHANGED IP ADDRESS TO WITHIN RANGE OF OTHER COMPUTERS SO ADAPTOR WOULD CONNECT. SHOWS GOOD CONNECTION BUT WILL NOT ALLOW ME ACCESS TO THE WEB.
  • Trish_R Apr 09, 2008
    I have a Linksys USB wireless adapter for my home PC. I had it up and running and it was working fine, but overnight something happened. I turned my computer completely off on Saturday night. When I tried to access Internet Explorer on Sunday morning, I got an error message stating the page could not be found, check your connection, try another page, and all that. My wireless indicator shows I have a good connection, but I cannot access the internet.
  • 178 Answers
Hello all Please call me so I may walk you threw this. Or if you prefer check your connection threw internet Exployer
Open it up and go to tools
Internet options,Connections,
Check to see if you have anything in there. If so please respond back to me
Posted on Feb 13, 2008
Using d-link glb-802 c router , now purchased another system , from router how should i connect to my another system
if the router is wireless and the new system is wireless ready then the router should pick up the signal fine and run the internet smoothly however some routers come with a security key examples WEP, WPA, WPA 2 these are the most common forms of security if this is the case you will have to enter the key on the router or in the User Manual before you have internet access... if the router is not wireless then you simply buy a new ethernet cable which now are fairly cheap if you know where to go depending on size and plug it in to the router and the appropriate slot on the computer system and this should connect you to the internet... if you system is not wireless but your router is you can now buy wireless cards that fit into the computer which recieves the signal from the router or a wireless adapter which does the same but plugs in via USB. any other information please feel free to talk to me but these options should solve your issue
Jan 19, 2012 | D-Link Computers & Internet
My router is connecting to the network and broardcasting the internal netowrk but not broardcasting any internet. The internet connection work fine if i plug the wire straight into my computer.
To connect to the router using a wireless connection, the computer's wireless card needs to be configured with the router's wireless settings, ie. SSID and encryption key.
The encryption key is configured in the router's wireless settings.
I suggest you use WPA or WPA2 encryption because it is the latest and provides stronger protection.
To change or see the encryption key and/or secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 30, 2011 | Linksys Wireless-G WRT54G Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
New motherboard makes my wireless nic loose signal.
It sounds like a driver issue.
I assume you mean the card worked previously on an old motherboard.
Remove the wireless NIC driver and then re-install it. I assume their are no yellow exclamation marks agianst your NIC in windows system properties? To see sys properties right-click "My Computer" select Properties/Hardware/Device Manager. Look for the network adaptors section. You can update drivers from here on your wirless card or even try the Troubleshooter tab.
if you don't have the driver CD let windows go onto the internet and search for a driver.
If you rely on the wireless card to connect to your internet connection, perhaps you can connect your computer to the internet modem or router via your computers LAN/network connection?
If that's not possible, download the driver from the NIC cards manufacturer website and pop it onto a USB thumb drive which can then be installed onto your new computer.
Last thought, make sure you are only using one controlling application for your NIC ie you use either the Windows Zero Config Utility OR the NIC cards manufacturer utily eg D-Link, Netcomm, etc etc
That is not both at once as windows has a major hissy fit.
See:
http://forums.whirlpool.net.au/forum-replies-archive.cfm/438290.html
http://www.netcomm.com.au/__data/assets/pdf_file/0020/17291/61_Using.pdf
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1378157.html
Cheers,
Steve
Mar 07, 2010 | Abit AV8 Motherboard
How to connect a netfear router to a dell computer
I assume the Netgear is a wireless router and you want to connect to the router using a wireless connection.
Make sure the DELL computer wireless card is installed with the latest wireless card driver.
The Netgear router needs to be configured with the wireless settings ie SSID and encryption etc.
Next the wireless card needs to be configured with the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
Dec 23, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
On my windows xp it says my internet is working but when i try and open a internet page it says it cannot load, please help
FIRST POSSIBLE SOLUTION: Determine which version of IE you have installed. To do so, click "Help" on the IE toolbar and then click "About Internet Explorer." The version will appear in a dialog box. Go to the Microsoft website and upgrade to IE version 7 if you are using an earlier version. By upgrading, you may be able to resolve your IE problems. Repair damaged files automatically using IE 7's "Reset" feature. Go to the "Tools" menu and click "Internet Options." Click on the "Advanced" tab. Click the "Reset" button. Close all other programs if asked, and then click "Reset" to confirm that you want to reset IE and repair the files. Use XP's System File Checker to resolve IE problems. Click "Start" and then "Run." In the "Open" box, type "sfc /scannow" and click "Go." The System File Checker will scan your computer, finding and repairing damaged or missing files. Restart your computer after the process is finished. Update Windows XP to make sure you have the most recent service pack installed. Go to the Microsoft Windows, check for any available updates and install them. SECOND POSSIBLE SOLUTION: Make sure your computer is not too far away from your wireless router and you have a good signal. By placing your mouse pointer over the wireless connection icon, located in the bottom right corner of your taskbar, you can check to see if your signal strength is good. Anything less than a good signal can cause intermittent connections. SOLUTION: You will need to relocate your wireless router closer to your computer. If you have a 2.4 GHz wireless home phone, take notice if you lose the internet connection when placing or receiving a call. These wireless phones interfere with wireless routers because they both operate on 2.4GHz frequencies. If this happens you need to power down the router and then turn it back on. This will happen occasionally but not all of the time. SOLUTION: (1) upgrade your wireless phone to 5.8GHz, (2) use a corded phone or (3) use a wired internet connection to your router. If steps 1 and 2 did not solve your internet connection, borrow a friend?s laptop with a wireless card and see if their laptop can connect to the internet. Be sure to set your friends wireless connection settings to the same settings that your wireless card is set to. If your friend?s laptop connects to the internet then you may have a bad wireless card. Try reconfiguring your wireless card settings before going out to purchase an external wireless card. If your friend?s laptop can?t connect to the internet, try resetting the router to the factory defaults. Change the settings on the wireless card to the same settings as the factory default on the wireless router. If this works you are back in business. If it does not work for either computer, the wireless portion of your router is bad. SOLUTION: Purchase a new router or use a wired connection to one of your router ports.
Sep 24, 2009 | Dell Dimension 3000 PC Desktop
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
D-Link DWL-G510 Connected but no packets
According to the user guide for your motorola broadband modem it doesnot support wirless capability , ie it can only hook your computers to the interenet using the wire. refer the following link
http://broadband.motorola.com/consumers/products/SB5101/downloads/SB5101_UG_EN.pdf
What is required , is additional pair of hardware ie.
1. Wireless Router(eg linksys or netgear)
or
2.Router/broadband modem(given by the ISP)
Your connection would then be configured through the wireless router , that would give you wireless capability.
Refer to the following link , it gives you the a step by step guide to setting up the wireless connection .
http://www.oreillynet.com/pub/a/wireless/2003/03/21/home_wifi.html
Best of luck .....
Thanks
mandeep
PS Do let me know if you need more assitance.
May 12, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
First I am not connected with the product that I am recomending in any way shape or form.
On a wired PC download Network Magic (the free version is all you will need). Burn a CD with it and install on the laptop. Bring up Network Magic and use it to connect to the network. If it can not find the network, run Network Magic on your wired PC and bring up the Network Map and look to see if you can see your router on the network. Log into the router and start by reseting the wireless.
http://www.networkmagic.com
I use this product on all my laptops and desktops it makes networking simple.
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
You may wish to check with OMNIQUAD to determine if the out of data antivirus package caused a firewall in their product to block internet access. See Link
http://www.omniquad.com/newsite/support/enterprise.asp
I have a a norton package that blocked some configuration options after the subscription expired.
Dec 07, 2007 | Edimax 4 Port Wireless AP Broadband Router...
D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter Logo
435 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
