My laptop won't start
Hp Pavillion zt1114 i think it has something to do with the battery or the motherboard thing that makes it start because it won't start even if plugged, i don't know what to do, i'd like to fix it myself
  • sul7an Mar 29, 2008
    I LOST MY CHARGER AND BOUGHT A VECTOR THAT DONT CHARGE THE LAPTOP, BUT ITS SUPPOSED TO KEEP IT POWERED UP AND I THINK I GOT THE POLARITY WRONG MY TX1000 DOES NOTHING
  • Don D May 11, 2010
    First - Its not the battery. If the laptop wont even start on AC power something else is wrong.
    2nd. Do you get the battery charge light when iuts plugged in?
    If not try another AC adapter - its the cheapest solution.
    What happens when you hit the power button? Do you get power but nothing on the LCD, or no reaction at all?
I am facing the same problem right now with my gateway notebook. My laptop will work with the battery atached but not with the power adapter plugged in. In a case like this, there is probably a problem with the motherboard. I disassembled my laptop and tested the dc adapter on the motherboard with a multimeter while the it was plugged in only to find that there was no voltage going into the circuit. I also noticed that the small post inside the dc adapter was loose. This tells me that I may have a bad dc adapter. But this may not be the case with your laptop but it is possible. If you are not able to do this test then I suggest you have it looked at by a proffessional. I you don't have any experience with circuitry you can easily damage your motherboard. HOPE THIS WAS HELPFUL.
Posted on May 17, 2008
I've tried other adaptors already... there's no reaction at all when i hit the power button. What else could it be?
Thank you for responding
Posted on Feb 11, 2008
How to replace video card on hp pavillion laptop
I think that it's intergrated into the motherboard, so I don't think you can.
Jul 21, 2014 | HP Pavillion dv9740us Notebook
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
The computer will not stay on. It is not the battery or the power. It is a hp pavillion dv6000z
I think it could be with power port at the side of the machine, check if there is any lights. Or it could be with the Motherboard. Try to use the battery with the laptop with the same model and do the same with the power adapter if its working with the other computer it could be the Motherboard thats having a problem. Check also if its having beeping sounds.
Feb 16, 2011 | HP Pavilion dv6000z Notebook
Hp pavillion wont start at all under battery power or under ac power..
I think its the Motherboard problem because if there is no power at all that means the hardware is already faulty. I recommend try to call the manufacturer or go to any computer local centers.
Feb 07, 2011 | HP Pavilion dv1000 Notebook
LAPTOP does not turn on. only fan runs.
Things to check first.
1. Make sure you have a new BIOS battery installed. Some computers will not start if the battery for the BIOS is dead.
2. The CPU may have overheated and no longer works. I lost a CPU and everything was dead.
3. A dead motherboard can also act in like manner.
Sometimes something will come loose on the motherboard causing a direct short which of course fries the motherboard and probably the CPU. Dropping a laptop can shake things loose.
My Daughter had this happen with hers. It was a 800 dollar HP Compaq and I had a heatsink come loose on my HP Compaq which fried CPU AND Motherboard. Beware of HP since they bought Compaq.
Jan 25, 2011 | Intel Computers & Internet
Hp pavillion dv6 laptop no power
1. Check the adapter
2. Check the processor
3. Check the motherboard if defective replace new one.
Note: You need to know the right spare part number of your motherboard e.i 443776-001. Here's a sample video
May 04, 2010 | HP Pavilion DV6500Z Notebook
HP Pavillion 6000 battery issues
Hi Steve, If you haven't gotten any batteries to work properly at all and the problems are different each time, I would say the motherboard is shorting out the batteries and causing weird problems. One last thing to try if possible..
Try a known good working battery, if that battery doesn't work then its verified that the motherboard is bad. If the known good working battery works in that laptop then you got a bad batch and it will be a battery problem.
Since your laptop turns on with the ac adaptor means that the ac adaptor is good.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion DV6701 SERIES LAPTOP
Usually it's a problem with the motherboard with majority of the HP DV series laptops. They just released an extended warranty that covers many of their models. You can check your warranty here:
http://www11.itrc.hp.com/service/ewarranty/warrantyInput.do?admit=109447626+1235504150969+28353475
If you'd like to try something yourself, I would recommend reseating the memory and booting your laptop without the main battery installed.
Best of Luck!
Feb 24, 2009 | Computers & Internet
Hp pavillion laptop dv9000 power on problem
I thing problem in heatsink use heatsink paste.
Oct 02, 2008 | Intel Motherboard
Computers & Internet Logo
183 people viewed this question
Alun Cox
David Payne
David Payne
