Question about Moultrie MFH-DGS-200 Digital Camera
Roblem with camera showing "CARD LOCKED' in the display window.
The camera keeps showing the SD card as locked. The card is not locked!
  • Anonymous Dec 23, 2007
    Me too.  Did you find a solution?  I haven't checked the camera for a number of months, so the battery drained completely.
I have the same problem on one of my cameras. I found this, http://www.chasingame.com/forum/viewtopic.php?f=9&t=2883&st=0&sk=t&sd=a
and going to give it a try.
Do a search for this problem and you'll find a couple of other things to try too.
Posted on Oct 14, 2008
I have the same probleme with my camera. The most amazing it's only happen with one of my two memory card i dont understand why?
Posted on Oct 11, 2008
Yep all it is , is a CLEAN the slot issue. It's NOT because your delete pictures on another camera
Posted on Oct 07, 2008
Occasionally the card port will get trashy. Try using a can of pressurized electronics equipment spray to blow out the port. I never tried a brush but if you had one small enough (use no metal brush) you could try that followed by blowing it out. It has worked for me a couple times.
Don
Posted on Jan 25, 2008
I don't know how to unlock card. I keep getting the message on the display that says Card Locked! and the camera will not function.
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
Apr 08, 2016 | Cameras
Hp photo smart camera has message in viewer saying card locked. what do i do?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 15, 2014 | HP Photosmart M415 Digital Camera
Samsung es60 card locked solution
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 22, 2014 | Samsung ES60 Digital Camera
Micro sd adapter i keeps in camera it is shows card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 18, 2013 | Canon Cameras
My camera shows" card locked! " how I unlock?
Nov 15, 2012 | Canon PowerShot SX120 IS Digital Camera
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
Apr 11, 2012 | Sanyo VPC-E760 Digital Camera
Display shows card locked,even with new sd card installed
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 24, 2011 | Moultrie D-50 Digital Camera
My camara has a display that says Card locked >
There is a slide button on the side of the card. One direction locks, the other unlocks. If this doesn't work, make sure you didn't buy an SDHD card for a camera that only uses SD. The error message shows if it's the wrong card. That was my mistake last week.
Nov 20, 2010 | Canon PowerShot A560 Digital Camera
My canon camera keeps displaying 'memory card' error and 'memory locked', what do I do?
check you sd card there is lock and unlock switch. unlock that button
Aug 08, 2010 | Canon Cameras
Its saying the memory card is locked. its not
if you have checked the SD card was not locked, you may need to open the camera to check the SD card slot inside,
here is a tips shows you where to check
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
May 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Moultrie MFH-DGS-200 Digital Camera Logo
115 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
