Security Systems and Surveillance
Problem for Security Systems and Surveillance
Generic problem for all Security Systems and Sur...
Westech 5000 battery low and i can't fig...
By pregger on Aug 25, 2009
My home security alarm system is beeping because of low battery and i can't figure out how to replace it. I am having a hard time pulling out the two black chips and nothing else looks like its replaceable. HELP!
I am trying to reach Westech but no one answers. Is this doable by ourself or do i need to contact someone..in which case who?
Best Solution
posted on Aug 28, 2009
Very Helpful)
Edju
Rank: Master
Rating: 94%, 10 votes
There are 2 posibilities for having a low battery. 1) Your main backup battery for the control panel is low, or 2) You have wireless transmitters in your system that use small batteries and need to be replaced. To replace the control panel's battery look for a large metal box which is the control panel. These panels are normally located either in the basement or a 1st floor closet. Open the panel if you have a key. If you do not have a key take a pry bar and pop the box so it opens. Inside you will find an electronic motherboard with a black & red wire which is plugged into the battery. Grab a hold of the connector at the battery and wiggle/pull until the wire/connector disengages. Do the same for the other wire. Take the battery to a battery warehouse store and have them match it up. Be sure when reconnecting the new battery to plug the black wire/connector into the balck marked side of the battey and red to red. If you have a wireless system you will need to pull apart one of the transmitters & see the type of battery used. Replace all the batteries at the same time. They will last normally 3-5 years. The control panel's battery will last about 5 years.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you so much. I was able to call the company and figure it out finally and they suggested the same thing. " - pregger
Popular Solutions for Security Systems and
Questions and Unsolved Problems for Security Systems and
Answer
i need wireless security that i can record to my computer (etc) that i use a/c power as main power.... (More)
Answer
craftsman garage door opener opens fine with remote, but when it comes time to close it will go... (More)
Answer
Door opens about 1 foot too far, the use of the travel up screw either appears to do nothing or it... (More)
Answer
I was able to get a green light to open but nothing would move. I replaced batteries and now my code... (More)
Answer
I replaced main sprocket & shaft today...now my opener will NOT travel down more than a few... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Security Systems... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
