Question about Flat Panel Televisions
LG TV picture problem
I have an lg tv and i am having picture problems, ikeep getting green and red dots appearing over my screen, when hooked up to dvd player,sky,and normal arial, is there anything i can do to solve this problem.
5 Suggested Answers
  • 899 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here
Posted on Oct 24, 2008
  • 27 Answers
SOURCE: Sky remote code
0206 usually works for LG
Let me know if any success
Posted on Apr 08, 2009
  • 3230 Answers
SOURCE: I need a code number to connect my Sky remote to
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
also check the below link -
Good Luck!!
Thanks for using FixYa
Posted on Mar 27, 2010
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Posted on Aug 07, 2010
SOURCE: sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
Posted on Dec 28, 2010
0 characters
1 Points
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Flat Panel Televisions
I have a 15 inch TV LG Smart TV something went out on it what could it be the model number is 50LN5700UH the LG light comes on but no picture
LG TV : Picture not coming on screen, but TV is on. - Forums - CNET > Forums > LG
CNETJul 14, 2014 - Dear All, Have a peculiar problem with my LG flat screen TV. It stopped working suddenly, that is no picture when switched on, I noticed the ... However, in my case the RED light keeps on blinking and there is a ticking sound ... LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
No Picture from LG 50PS60 Plasma TV
Nov 16, 2013
More results from
? 5:29
Jan 25, 2013 - Uploaded by Tampatec Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... came on good with green light working properlybut still no picture.
Oct 20, 2015 | LG Flat Panel Televisions
Red dots all over my screen
try to check the t-con board if it is lcd tv..If it is acrt tv ,try to check the transitor drivers for the RGB located at the back of the tube
Mar 17, 2014 | Flat Panel Televisions
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
My lg plasma tv get this smaal red dots over the whole screensome times this red dots are gone and then it returnswhat is the problem it is 2 and a half years old
This is a common fault on all LG sets with few people offering any solutions. I can offer a solution that could remove 95% if not 100% of the dots.
Remove the back of the set, there are about 40 screws. On the left hand side on a circuit board you will see 3 or 4 blue plastic boxes with yellow screw adjusters in them. The only 2 you are interested in are VR3 "setup" and VR2 "setdn". Mark the location with a marker pen so that you know where the factory settings were. Then turn VR3 fully clockwise. If this does not get rid completely do the same with VR2. This worked for me today, I was about to throw the TV away but I now have a 95% improved screen, sharper and more vibrant picture and saved hundreds. Hope it works.
May 21, 2010 | Flat Panel Televisions
My 20 lg powers up, red light turns green, but no picture comes up, the channel id shows then it goes dark. I can wait up to ten minutes still no picture unless I change the channel a few times then it...
You wont want to hear this.....
Green dots on a LCD screen are burnt out pixels and unfortunately are incurable other than having the TV serviced at a high price. One of the reasons it is a good idea to get a warranty on these types of TVs is primarily due to this very problem....burnt out pixels.
Please rate my help++++Thanks for using FIXYA
Dec 01, 2009 | LG 20LS7DC 20 in. LCD TV
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
Flat Panel Televisions Logo
748 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
