Question about LG (CRD-8400CB) CD-ROM Drive
The cd-rom door not open
The door of my cd-rom not open when i press the eject button , i heart the motor sound but the dor not open?
  • Anonymous Aug 05, 2008
    the door on my cd rom will not open when i eject it sounds like it wants to open i hear the motor i have tried a paper clip did not work
    the door on my cd rom will not open when i eject, i hear the motor but nothing happens.
    i tried the paper clip does not work
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Posted on Dec 04, 2007
You must to have a cd inside your cd-rom always
to eject the door of cd-rom without problems
Posted on Sep 24, 2008
The CD rom tray will not open.
just watch carefully on cd drive front there is a tine hole somewhere below the door area . now u need a very thin rod or something to insert in to it. there is a button inside that hole so while pressing that button press the eject button. hopefully ur cd drive door will open
Apr 20, 2010 | IBM -3509707 External 4x CD-ROM Drive
How am i going to eject the disc manually?
Hello there:
This sounds like to me that your cd rom device is going out on you when the disk gets stuck and refuses to come out what you can do is to get a paper clip and sraightren it out now look on the cd rom door and you will see a verry small hole if you press in on the door button and insert the paper clip in the hole when you see the light for the cd rom door turn on press in on the paper clip failrl hard and it will release the locking mechanism and the door will open for you.
you can try to clean the entire tray and the slides tht the tray runs on get some canned air and spray the area really well on both sides and see if this helps
If not that you may want to consider havaing the cd rom drive replaced ok
Hope this is very help ful for you
Best regards Michael
Jan 16, 2010 | Dell Studio 15 Laptop
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Dvd-rom drive doesn't open
Sounds like the drive eject motor is broken, maybe time/easier to by a new DVD Burner?
Mar 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
What can i do to open the door on my ez-dub
HI Buddy If your cd drive not opening no prob haah,, i have solution to open this, near by your cd room button there would be whole tiny whole ok, you have to do that when u pressed the button same time your have to entered the pin in to whole then your cd drive will come out easily.
if u will suceed then reply me plz ok best of luck.
Feb 28, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
CD Rom Driver door won't open without using the straightened out paper clip or pressing the driver door button upwards of 15, 20 or maybe 25 times. It will eventually open after repeatedly pressing for...
If this happens with all your CDs and everytime, I would suggest you should replace your CD Rom Drive with a new one. After use of some years CD Rom Drives have such problems. Otherwise a software might locking your drive. you should find a tool which unlocks the drive and then press the eject button.
Oct 06, 2007 | Acer Aspire M1640 Refurbished Intel...
LG (CRD-8400CB) CD-ROM Drive Logo
664 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
