KitchenAid KUDK03ITBK Built-in Dishwasher Logo
Anonymous Posted on Aug 25, 2009
Dishwasher won't empty all the water at the end of the cycles. Part of the water is draining as I can watch it in the disposal, but about an inch remains.
Josh Peck
Level 2:
  • Expert 91 Answers
  • Posted on Aug 26, 2009
Josh Peck
Expert
Level 2:
Answers
91
Questions
0
Helped
25369
Points
239
Check float sensor at the front of unit and make sure it is clean and not getting stuck. Otherwise timer may not be timing out dump cylce.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Testimonial: "Information is right on!"
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 • Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
We have 3/4 inch of water in base at end of cycle. is this normal? what to do?
No it isn't normal their shouldn't be any visable water in the tub at the end. You can firstly check filter by removing lower rack and unscrew the filter asm. espically the round basket for blockage,if that is clear reinstall it and check your disposer that the drain hose connects to in most cases for blockage, if sink drains normally the disposer is ok. If you have one check air gap on sink for debris in it,it's a chrome(most of the time and in some cases a different color) cap that sits up about 2 inches somewhere on the sink. While it deals with a different brand i have included a youtube video that will show you how to check air gap.
http://www.youtube.com/watch?v=EB19fRL5fhc
Good luck,i hope this helps
Gene
Our dishwasher will not drian out all the way. I cleaned out the screen and sump and it still does not drain out all the way. I also ran the unit and waited for the drain cycle and it seemed to flow...
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain, the largest percentage of them were simply because of a clogged drain hose or pump strainer. Too many people seem to think that the dishwasher is first cousin to a garbage disposal. It is not.30 Apr 2010
SOLVED: Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
1helpful
2answers
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
