Subject: SYBA SD-SATA-IDE-B Tuesday – 25 August 2009
When I bought a SATA Hard Drive for my second computer IDE slot, I purchased the only type of IDE-SATA dongle they had in stock. As it turns out I got the one for a SATA BUS to an IDE Hard Drive. Is it reasonable to use a gender changer on the end of the IDE ribbon connector [Master Position if need be] to interface with the dongle I have? I presume that the SATA and IDE bus and Hard Drives interface universally with their own type of BUS/Drive. The computer is an eMachine T2896 and the hard drive is a Seagate 1TB 3.5 Inch 32MB Barracuda Model Number: ST310005N1A1AS-RK. Any recommendations would be helpful.
To better assist with your request, you can bring it or call BITS at 1344 Idaho Street in Elko nevada. More contact information available at the website www.bitsofelko.com
How I solved the SATA IDE Dongle problem: I looked up various devices that perform this task and I found that some of them are bidirectional with a switch attached to them to internally facilitate the necessary configuration change. I plan on buying a PCI card with SATA ports to accommodate my switchover as it makes it easier to have my previous secondary drive connected so I can easily transfer files and provides a means of having more than two hard drives on my computer should I find the need in the future.
ultra max 1TB, mac os x, "do not have permission to view the contents of this drive", but...
(More)
ultra max 1TB, mac os x, "do not have permission to view the contents of this drive", but I have admin access to the machine and the usual method of fixing permissions has not worked.
i want to install iomega 320gb.i need the driver for windows 98se to instal it.where i can find the...
(More)
i want to install iomega 320gb.i need the driver for windows 98se to instal it.where i can find the driver
