GE Air Conditioner
Problem for GE (AJCQ08ACB) Air Conditioner
Air condioner climbs to 86 degrees
By jabdk on Aug 25, 2009
Same problem with 5 year old GE 24,000 BTU window unit....just yesterday the temp started climbing to 86 all by itself.....sometimes can get it to come down, sometimes not....when comp. is running it blows cold, about 46 degrees.....however very little sweating on pipes from comp. Cannot say how long comp. will run..maybe 5 minutes maybe 30.
Outside air is 90 degrees 90%humidity.
Could this be low on Freon and unit is protecting the comp. by raising temp to turn it off?
Solution #1
posted on Aug 26, 2009
Not Rated)
drberry
Rank: Guru
Rating: 93%, 86 votes
First check your coil behind the filter. If this coil iss clogged the unit will over heat and cause the compressor to shut down. It sounds as if either the evaporator coil (inside) or the condensor coil (outside) may be clogged. If the unit is icing up on the inner coil then that coil is clogged or low on freon. I would think it would be cloggged instead of freon problem. To clean this coil you can go to the hardware store and buy a can of coil cleaner and use it following the directions The outer coil you would have to remove a/c from sleeve and take the unit outside. Using a water house flush the condensor coil from the outside in to remove debris.. These coils should look like a brand new car radiator when you finished cleaning. Reinsert the a/c back into wall sleeve after letting the water evaporate from the unit as to not spill water through out the area. Good Luck
Dave
Was this helpful?
Yes
No
Popular Solutions for GE Air Conditioner
Questions and Unsolved Problems for GE Air Conditioner
Do you recommend GE (AJCQ08ACB) Air Conditioner?
Answer
Answer
the frotn panel is not working since yesterday and both remote controllers (I bought 2 units) are... (More)
Answer
It stays on 86 degrees and when you push the down button it goes up even higher. Please help??
Answer
Digital code EP on face panel
Answer
my remote isn't working. i changed the batteries and the remote DOES work on another AWE08AJS1. is... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
