Question about Fuji FinePix A303 Digital Camera
Camera makes clicking sound but doesn't take pictures
I've gone through all the trouble shooting and the camera just clicks and beeps but doesn't take pictures or video. I've switched out the batteries and picture card. Any other suggestions?
  • gstratton Jul 28, 2008
    I reformatted the disk (under menu while in the play setting) and it fixed my problem once. now it's stopped and formatting is not helping.
    when I press the top button, I hear a beep and the LCD freezes, however no picture is loaded on the card.
  • Anonymous Aug 14, 2008
    I can
  • 36 Answers
The gears in the lens are either jammed with sand etc. . or broken. Most likely you need a new lens assembly, although sometimes the gears can be replaced.
Posted on Jun 10, 2008
My screen has gone white?
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
Dec 14, 2011 | Nikon COOLPIX L20 Digital Camera
How does this thing work?
Install the software on your computer. Put a battery in the camera. Push and hold the button to turn it on (display shows 00) Take some pictures - the camera makes a tiny beep, the led on the front flashes, and the count goes up by one. Push and hold delete to remove the last picture (count goes down) hold longer to delete them all (goes to 00). When you've collected some pictures, rush to your computer to download them with the USB cable before the battery runs out; when that happens the pictures are all gone (there's no flash memory in this). Holds about 40 pictures depending on the amount of detail in them.
Feb 03, 2011 | Disney Pix Click Digital Camera
I had about few movies and lots of pictures on my camera that i;ve taken,and they were all gone.some of them stayed there but the rest i dont know where are gone.while i was shooting picture,on my camera...
Get yourself a card reader and use it to download your pics and movies to your computer. Then, format the card in the camera to get it working properly.
Feb 28, 2010 | Olympus SP-320 Digital Camera
My d 80 gives an err message on the lcd and r 09 is flashing on it, the shutter just clicks and makes the sound but no picture taken, i am frustrated please help
The r09 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message2_bing.gif. If the camera isn't taking a picture, then it's something unrelated to the R09 message. If the shutter clicks, then it probably IS taking a picture.
Jan 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
Nikon D50 While shooting pictures the shutter button stopped work
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
When take photos it looks in focus through the viewfinder, but the pictures come out slightly out of focus
I'm not sure what camera you are using. But I believe you are taking pictures like the old Kodak Instamatic which you just literally point and shoot. Even then people took blurred pictures. There are 2 reasons I can guess. First is you are pressing the shutter button too fast. When you press the shutter, it should be like squeezing the trigger of a gun. You SQUEEZE slowly. Not press the button and let go. After you hear the camera has done all the sound it wants to make that means you picture is being recorded. And hopefully it will be clear. If it still isn't then it means your camera take a little bit longer to focus on the subject. That's what happened to my wife. She thinks she can point and shoot and that's it. You need to camera a few seconds to focus. I know the Casio's have a little beeping sound that tells you it has focused and is ready to shoot. My Konica Minolta does the same but I see a box on the screen (I took the sound out). You need to listen for that tone that tells you you camera has focused on a spot and is ready to shoot. In order for the camera to do this you need to press the shutter only half way. When you hear the tone then slowly press all the way and don't move till all the clicks are done. That's usually 0.5-1.5seconds only. Hope this helps.
Nov 19, 2008 | Canon Cameras
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Oct 24, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
I installed my 913D camera driver and after some trouble and it tells me that there is a connection problem and to trouble shoot. I've already uninstalled and reinstalled and it still isn't working.
Follow steps below :)
Open “Windows help and support” window.
Type “Program Compatibility Wizard “ in the question box.
Select “Click to open compatibility wizard”
To continue, click Next.
-------->> I want to choose from a list of programs
-------->>Select a program: 913D Camera
-------->> Microsoft Windows 95
-------->>640 x 480 screen resolution
-------->>Run this program as an administrator
Run 913D Camera Software. Should be able to connect and manually download pictures. If not try different OS settings.
Sep 10, 2008 | Cameras
Lenc cover will not open
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 12, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Wont speed up even with new batterys
The shutter button features a two-stage action. shutter_button.gif Pressing Halfway Pressing halfway automatically sets the exposure, focus and white balance.
The indicators light or blink as follows.
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
Sep 24, 2006 | Canon PowerShot A400 Digital Camera
Fuji FinePix A303 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
