Question about Pioneer CDJ-800 Turntable
No power my cdj wont even turn on....the power is running to the cable to the cdj but nothing is happenin with the cdj itself....no power...any ideas...thanks in advance
  • le2g Dec 09, 2007
    no power
  • 515 Answers
You probably have a bad transformer. This is not an easy fix. You will need to contact a service professional for assistance.
DJPROAUDIO
TWEAK AV LAB
Posted on Jan 19, 2008
2 Suggested Answers
  • 7 Answers
SOURCE: power
You need to check internally, Transformer/rectifier could be bad, disconnected wire, blown internal fuse. Can you rub the needle with your finger and get sound? Is it just the table not turning or is the needle not getting "power" either?
Posted on Dec 18, 2007
Hi, have a problem with my one of my pioneer cdj 800 players: every time I switch them on, they don't launch simultaneously; while one is working properly, the other one needs up to five minutes to...
my problem is that my cdj 2000 loses power when I switch it on
it comes on and after like 5 seconds , it just shuts off and wont come on when I switch it back on
email me with any suggestions, nav2u@hotmail.com
Jun 13, 2013 | Pioneer CDJ-800 Turntable
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
My ruud achiever 90 plus furnace wont run. thermostat shows system on, seems ok but furnace itself wont run. system has power.I can hear the power come on when I depress the access panel switch and also...
See if you can locate the control board. There should be an automotive push in fuse on it. It should be a small amp fuse around 3-5 amps. Check it and change if needed. You should be able to see if it is blown or not just by looking if you don't have access to a multi-meter.
The control board is usually located in the blower compartment. Thank you.
Jul 10, 2011 | Ruud Heating & Cooling
New CDJ1000 MK3 freezing and then turning itself off
CDJ 1000 mk 3 freezing while playing tracks and sometimes freezes when a cd is inserted. The orange cue light comes on but the green play doesnt. Any ideas?
Thanks
Sep 25, 2009 | Pioneer CDJ-1000 CD Player
Pioneer CDJ-400 won't turn on.
sounds like a fuse, is the red stanby light on? if it is and it wont power up , then you may have blown the thermal fuse in the main power transformer
Jul 11, 2009 | Audio Players & Recorders
I bought two cdj 800 from the usa and they wont power up
nothing to do with hz.adjust country voltage&turn ON
Jul 05, 2009 | Pioneer CDJ-800 Turntable
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Power
Dec 04, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
228 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
