Question about Refrigerators
GE side by side problem
Coils are frosted over and it will not make ice or keep the refrigerator part cold. This refrigerator is only a year old.
FREEZER WORKS FINE, BUT THE REFRIGERATOR IS NOT AS COOL AS IT SHOULD BE. I MOVED THE THERMOSTAT UP TO 7, BUT STILL IT IS NOT AS COOL.
  • 1 more comment
  • Hepsy Dec 20, 2007
    Refrig section will only cool to 43 degrees. Freezer side is fine. Refrig is only 18 months old. No noises coming from it except for a very soft hum.
  • KHuml Feb 29, 2008
    The Freezer on My side by side works fine foods stay frozen. My refrigerator does not get cold like it should and I have turned it up all the way to 9
  • shocklin Aug 02, 2008
    Same problem. Sears has been out 6 times over 2 years, replaced "motherboard", tempersure proble, other digital parts. Works for a few weeks, then, starts over: freezer works but refrig. side warms to the 50's.
    Tried use hair dryer to defrost coils so that air will channel to the refrig side. Works slightly, but then stops.
    Sears has never responded in less than a week! Food gets lost. Next refrig will not be from Sears.
Be sure the evaporator fan is working if not it is stuck up because this seldoms. Open evaporator coil and check the defrost heater and defrost termination switch for resistance and continuity. If both are good then the defrost timer is bad. Replace.
Posted on Sep 27, 2009
  • 139 Answers
Before you waste any money my advice would be to defrost the the whole lot for 24 hours and then put it on... most times this works..
Posted on Dec 04, 2007
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
GE side by side keeps frosting up and fridge is not very cold
It sounds like you have a defrost system problem. most commonly its your defrost heater on most GE ref. It can be located by removing the back panel of the freezer. If you remove the heater it can be tested for continuity at any parts distributor. I would also look for the quarter sized thermostat mounted at the top of the coils to see if it looks "popped" at the top. If it is then replace the thermostat. Hope this helps MJ
Jul 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side
Something has gone bad in the defrost circuit.(Heating element was notorious for this) but could be a timer or thermostat. Frost buildup will cause inefficient cooling as will dirty condenser coils.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side refrigerator quit working.
The automatic defrost system is not working. All frost-free machines have a heater in the freezer to melt the frost away on a timed schedule. Every day or two the defrost cycle is initiated by the defrost timer. A heater melts the frost, then the cooling system is turned back on.
Mar 06, 2017 | Refrigerators
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
You will have to make some line and low voltage tests at the motherboard to diagnose this further. Start by removing axcess panel to motherboard on back of refrig. Locate 3 PIN blu connector on bottom of board. Wires are labeled Comp, Def, Line. Jump Line to Def At connector. Look at heater at bottom of evap coil for glowing red heat. If no heat heater is bad, if it does heat time to go to the next step!
Dec 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
