Question about Videoseven V7 E17PS 17" LCD Monitor
Missing 1/3 of the display
I have been trying to use a monitor off my dads old pc, it worked fine on it (a tiny so its pritty old!) However on every pc and even when hooked up to my laptop the right hand 3rd of the screen is obscured by vertical coloured lines or somtimes jsut darkness. This is obviusly infuriating, any surgestions?
    Genius:
  • Videoseven Master
  • 1,689 Answers
This could be a failure in the screen panel or the matrix driver on the circuit board driving the screen. On rare occasions it could be a bad ribbon connect or cable that feeds the screen. This is not normally something you can fix yourself. You would need the proper service setup and spare parts to try.
Considering if the monitor is out of warranty and is aged it's best to get a new one.
Posted on Jan 04, 2018
Hp probook 470 g1 starts fine but nothing on my screen, works on my tv but not laptop. only a week old have I done something
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
Apr 12, 2014 | HP Pavilion dv7-1130us laptop
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
I've had this same issue! My Wacom Cintiq 12WX tablet has been having this "Signal out of Range" issue all of the sudden with my Mac OSX Laptop. I've bought and tried new DVI cables and...
Hi 13ambreuer
is a problem between the graphics card, monitor, motherboard or graphics card port.
if you have to do troubleshooting on the monitor and display card, proved no problem to it. This means that the problem now is the motherboard and graphics card port.
(But should remember, problems ram, power supply and processor also causes the same error) * Sometimes *)
mean here you have to do the troubleshooting on all hardware on your computer
thnks&regards
Dec 08, 2010 | Wacom Cintiq 12WX Interactive Pen Display...
Hello, I am trying to trouble shoot a Toshiba Satellite a70-s256 laptop. When powered up, the lights go on but there is nothing on the screen. I am attempting to use an external monitor to further...
Hi Barb,
On the Toshiba A70 you should try holding down the fn key at lower left and pressing the F5 key which is the video transfer keyboard command for pretty much every Toshiba laptop. Otherwise, their little pictograms on the F keys almost always have a tiny representation of a laptop next to a monitor.
Hope this is helpful.
Sep 09, 2010 | Toshiba Satellite A70 Notebook
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
When i link webcams with my dad he can see me and we can hear eachother but i cant see his webcam. what could be the problem??
At your dads end, does it show that his webcam is being viewd..? It could be that there is not much light at your dads end.
Sep 24, 2009 | HP Pavilion dv6000z Notebook
Tiny ------------- all over screen,Dell is no help.
your monitor has came in contact with some magnetic material remove all the things containing magnetsfrom around it and leave monitor unplugged for 1 day and then start it will work fine
pls rate my solution
Feb 19, 2009 | Dell XPS 410 PC Desktop
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Videoseven V7 E17PS 17" LCD Monitor Logo
Top Videoseven Computers & Internet Experts
Alun Cox
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
