Question about Amana ALW880WH Top Load Washer
Amana washer has no hot water - cold works fine
No hot or warm only cold
  • sky123 Dec 12, 2007
    washer only will rinse with hot water no cold rinse no cold water comes into washer at all.
  • Anonymous May 08, 2008
    hot water only trickles out, what is the fix?
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Posted on Dec 29, 2008
Washer fills very slow
Posted on Jan 06, 2008
  • 164 Answers
Check the screen in the water valve and the screen in the hose. clean or replace. if that doesn't cure it replace your inlet valve. if that doesn't fix it, turn the hot water back on.
Posted on Dec 05, 2007
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Washer has cold and warm but no hot hot wash
check water temperature switch and the water inlet valve
Apr 14, 2014 | Amana NTW4600VQ Washer
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Amana Model LWABOAW Manufacturer # PLWABOAW Age: Approximately 12 years. Ran fine up to now. This morning the machine would not run using Cold/Cold setting. If the Warm/Warm, Warm/Cold or Hot/Cold...
I believe the issue is with the water inlet valve assembly going bad and should be replaced, this unit has two valve one for cold and another for hot. You can test the valve first if that is fine then check the pressure switch which is part#4 in this diagram. Hope this helps...please post back for further assistance.
Jan 19, 2011 | Amana Washing Machines
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Washer will run with hot water only ( amana heavey duty washer)
What if you swap the hot and cold lines on the back of the washer? Does the problem remain the same? Only you get cold water OK but not hot? The test I suggested is to verify if the inlet valve for both hot abd cold are operating and by switching the hoses, the problem should switch with them if the inlet valve is not opening when it is supposed to, Please provide details on the make and model of your washer so I can look at the control circuitry to determine how the inlet valves are operated.
Nov 25, 2008 | Washing Machines
Cold water not dispensing
the water valve is bad replace ,Water inlet valve kit
Recommended related item(s): 782959
Apr 21, 2008 | Amana ALW480DA Top Load Washer
Amana ALW880WH Top Load Washer Logo
1,015 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
